timing 428cui, 670 heads - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 07-26-2011, 06:57 AM   #1 (permalink)
Hi!
Now I'm sure what setup I bought with my GTO and I think the timing might be incorrect, because I used values from the original 389 cui.
I have:
- 428 cui from 5.14.1969
- 670 heads from 1967
- tri power setup from rochester
- headers and 3" exhaust
- flowkooler high volume aluminium waterpump
- high flow thermostat 160
- msd ignition (distributor...)
- accel 137 spark plugs
- mallory spark plug wires
If I use the highest available octane the engine sounds good, is my compression too high? I'd like to run 95 octane without engine knocking, could it be a timing issue?
Chris
Chris-Austria is offline   Reply With Quote
Old 07-26-2011, 12:45 PM   #2 (permalink)
My Photos: (12)
Hi Chris,
670's on a 428 are going to put your compression "up there", but the real test is whether or not the engine knocks and/or you're finding tiny shiny specs of metal on your spark plugs. 670's are closed chamber heads and as such their combustion efficiency isn't as good as the open heads, so to make the most power they're going to need a little more ignition timing than an open chamber head would.
Is the motor knocking now? When you examine your plugs, are you seeing tiny shiny specs? (A motor can be not knocking but still detonating and damaging itself - the shiny specs are bits of piston).
Garland, TEXAS
BearGFR is offline   Reply With Quote
Old 07-26-2011, 01:38 PM   #3 (permalink)
Thumpin455's Avatar
My Photos: (5)
That combo with flat top pistons is going to be well over 10:1, not far from 11:1. Depending how Austria tests for octane, 95 might not be enough. I know it isnt enough here with our gas, that thing would knock the upper rod bearings flat in a few hours. Been there done that with a 400.
Thumpin455 is offline   Reply With Quote
Old 07-26-2011, 02:29 PM   #4 (permalink)
I'll remove one or two plugs and check them.
If I use 95 octane (would be 91 in the US) the engine knocks.. if I use 98-100 (would be 94-96 in the US) it sounds pretty good. I also add some lead additive..
Timing is now at 7-8 I think, but it has been at 10 before I set it down... should I use 10?
Motor isn't knocking now since I use 100 octane and lead additive! But that makes fuel pretty expensive.. it consumes about 25 liters/100km (9,5 mpg)
Old 07-26-2011, 04:04 PM   #5 (permalink)
My Photos: (12)
The big thing is making sure the motor doesn't knock and isn't slowly eating pistons. Everything else is secondary to making sure of that.
That being said, with 670's I'd probably start with timing at 34 degrees TOTAL (vacuum advance disconnected, engine at 2800 rpm or higher) and see how it likes that. Add more a degree or two at a time until you find the point where performance starts to decrease (or you start to see/hear signs of detonation), then go back to the previous setting. Then measure to see what that works out to on the initial side (motor at idle, vacuum advance disconnected) just so you'll know where to set it the next time you need to.
You want to run as much timing as you can until either performance degrades or you see/hear signs of detonation, which ever happens first.
Garland, TEXAS
Old 07-27-2011, 04:56 AM   #6 (permalink)
Like always a very good advice, I'll try that The vacuum advance is a part of the distributor? Mine doesn't have such a thing at all.
Maybe I'll ask the shop to check my compression ratio as well if that isn't to complicated and expensive.
Old 07-27-2011, 10:05 AM   #7 (permalink)
with 670 heads on a 428 there is no need to have anybody check it. its too high for pump gas. period.
you can try retarding timing to less than 6 and try limiting the advance but those are bandaids. you need different heads.
freethinker is offline   Reply With Quote
Old 07-27-2011, 11:43 AM   #8 (permalink)
My Photos: (12)
I keep forgetting you don't have a factory distributor. The vacuum advance would be evidenced by a vacuum line connected between the distributor (usually on the side next to the bottom edge of the distributor cap) and either the intake manifold or the carburetor. For distributors that have them, it's important to make all timing adjustments with the vacuum line disconnected and plugged.
There's no way that I know of to measure compression ratio without removing the cylinder heads. Checking cylinder 'cranking pressure' with a gauge doesn't provide an accurate measurement because that measurement is heavlily influenced by the cam profile --- the "later" the intake valve closes, the less pressure will be - because compression can't begin until that valve closes. Speaking of, that's another "band aid" that's available: if you use an "adjustable" timing chain/gears you can retard cam timing "a little" to delay that intake valve closing event some and it just might be enough to keep the motor out of detonation if it's already "close". Retarding cam timing has other consequences though - it shifts the torque curve higher in the rpm range so the motor's going to have less torque at low rpm and also will need to turn to a higher rpm in order to make maximum power.
I just ran "numbers" for 670 heads on a standard 428 (4.12 bore, 4.00 stroke) and assumed a standard factory compressed gasket thicknetss of .042 with the pistons .020 "in the hole" at TDC - which is what Pontiacs "usually" are from the factory unless the block has been decked. I also assumed flat top pistons that have about 6 cc's worth of clearance volume in the valve reliefs. Factory specs for 670 heads state that their chambers have 72 cc's of clearance volume. However Pontiac heads have been known to vary from factory specs quite a bit in either direction, and also we don't know if your heads have ever been milled/surfaced, so the only way to know for sure would be to pull the heads and measure the chamber volumes directly. With all the "disclaimers" out of the way, that combination works out to 10.549:1 static compression using nominal factory measurements. That's probably too high for any pump gas we have available here in the States, I'm not sure about what you can get there in Austria. It might be possible to squeak by with a really nasty (long duration) cam and top notch cooling system, but I wouldn't try it myself. Just on numbers alone it's not worth it to push compression to the limits. On my 400/461 the difference between 9.4:1 and 10.5:1 is only worth about 14 peak horsepower - not worth it to me to take the risk of destroying the motor for just 14 HP.
To see the effect of chamber volume on static compression ratio, if we just add a measley 6 cc's of volume to each chamber 'somehow' (piston dish) that drops SCR to 9.96:1. If we triple the volume to a total of 18cc's (acheivable with off the shelf D-dished pistons) that makes SCR 9.44:1 - streetable on U.S. 93 octane if you're careful and have 'enough' cam.
Aluminum heads would be a different story. Aluminum doesn't retain heat like cast iron does so you can get away with more compression. 10.3:1 or maybe even 10.5:1 with aluminum heads is doable (given the right cam and a good cooling system).
Like with lots of things on cars, it's all a compromise and there's no hard and fast rule due to all the interelationships between the various components and the overall condition. A poorly planned/sloppily built motor might rattle like a load of loose bowling balls in a box car even at only 9:1 on 93 octane, while a very carefully built and meticulously maintained one might be ok at close to 10.1 if everything is always "dead on" and the fuel mixture/tune up always "perfect".
And... it's not that I'm an expert or anything on this topic, it's just that I spent BOATLOADS of time and effort researching it during the time I was planning and building my own 461. I was in a situation similar to yours. I had a set of original 1969 #722 Ram Air IV cylinder heads that I -really- wanted to use just for the cool factor, but in order to get the compression ratio down to something reasonable on a 461 I had to jump through a lot of hoops to do it, when it would have been "easier" to just get a good set of aluminum heads (which probably would have made more power than the IV's anyway). As it is though, I've got a 461 that makes fairly decent power that I can point to and say "yeah, it's just the factory 400 - nothing special" and MAYBE get away with it except with Pontiac-heads that know how to interpret all the various codes and numbers - at least until I start it up
Garland, TEXAS
Old 07-27-2011, 01:05 PM   #9 (permalink)
My Photos: (16)
I though NASCAR had a tool that inserted into the plug hole and did some whistle thing and they could determine compression ratio??
Restoration pictures password is 'GTO'
Burn-out videos.
Rukee is offline   Reply With Quote
Old 07-27-2011, 01:13 PM   #10 (permalink)
Thank you for calculating how high my compression would be, if everything is still like it was build. The guy at the shop told me the same thing.. it's not possible to measure the ratio and I shouldn't worry too much if it doesn't sound to bad when using the highest available octane (would be about 96 in the US). I'll drive it empty (now I use 94) and fill it up with the 96 and add some octane booster.
Which heads would fit best to the 428? (Many hp and a good compression?)
I like it if an engine looks factory and has a setup that is good for some surprises
#670 or 6x heads bobby326 1964-1974 Tempest, LeMans & GTO Technical Discussions 11 12-01-2011 10:24 AM
670 heads 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical Discussions 3 10-11-2010 11:59 AM
67' 670 Heads zzomby 1964-1974 Tempest, LeMans & GTO Technical Discussions 14 07-27-2010 10:57 AM
670 heads journeymate 1964-1974 GTO General Discussion 1 11-13-2009 04:26 PM
670 heads BYTOR84 1964-1974 Tempest, LeMans & GTO Technical Discussions 9 11-10-2009 09:08 PM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
