Timing marks - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 02-13-2012, 11:00 AM   #1 (permalink)
66goatframeoff's Avatar
Timing marks
So being an ol fart and trying to remember timing chain marks have searched the threads and now more confused than ever I have always set cam at 6 and crank at 12 however my 400 was put togeter 4 years ago and run once so Idecided to put new rear main in while it was out when I bring #1 up comp stroke bal points to 0 and marks are at 12-12 does anyone have a picture of the correct timing marks for a 70-400 my book so old pages for eng o/haul unreadable heeelp..
66goatframeoff is offline   Reply With Quote
Old 02-13-2012, 11:08 AM   #2 (permalink)
My Photos: (12)
Actually, it doesn't matter - both orientations are correct. Remember that the crank makes two revolutions for every one revolution of the cam, so if you install the chain with the marks "one way" and then spin the crank over exactly one revolution, it's going to be "the other way". What matters is making sure that at TDC on the crank, the marks line up with each other. Then when you get around to installing the distributor, the rotor is pointed at #1 cylinder whenever #1 cylinder is near TDC on the compression stroke --- and I too forget whether TDC compression is with the cam timing mark "up" or "down". I just turn it over by hand and watch the rockers on #1 and the timing marks. When I see the intake valve close, I know that when the crank next says TDC #1, that's compression.
Garland, TEXAS
BearGFR is offline   Reply With Quote
Old 02-13-2012, 11:48 AM   #3 (permalink)
facn8me's Avatar
My Photos: (8)
Yep, just crank it around one more revolution at the crank and the dots will be lined up.
http://www.gtoforum.com/signaturepics/sigpic18842_1.gif
1966 Pontiac Lemans Convertible
389 tri power
facn8me is offline   Reply With Quote
« 67 a/c car | t56 »
These damn water marks! pushin400 Exterior Discussions 10 07-19-2011 12:08 PM
Timing Covers and Timing Pointers ride400 1964-1974 Tempest, LeMans & GTO Technical Discussions 8 11-24-2009 08:11 PM
Where are the timing marks on 455 HO? clarkaim 1964-1974 Tempest, LeMans & GTO Technical Discussions 2 06-19-2009 06:20 PM
What do YOUR skid marks look like? WanaGTO Drive train, suspension, alignment and brakes. 10 02-05-2009 08:14 PM
Swirl Marks in Paint ? lotaguts Exterior Discussions 8 02-24-2006 02:23 PM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
