Timing on Pontiac 400 - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 02-24-2011, 10:20 PM   #1 (permalink)
Ok i have looked everywhere and cannot find a correct solution or question to this so here goes. I have a Pontiac 400 bored .60 over ported and polished 6x-4 heads, edelbrock performer rpm intake and cam, 1.65 roller rockers, edelbrock 800 cfm carb, and hei distributor. The only way to get it to start is if I set the timing at roughly 35 degrees what I believe is before top dead center timing mark on crank is under timing marks on engine. it idles around 700 or so with a little bit of a lope. I have heard that a 400 running 6x-4 heads is going to have higher compression and the cc's in the heads are around 90 or so, and the only way to get the engine to compesate for the higher amounts is to have the timing off by quite a bit. Do this seem right? Is there any ill affect to having it set this way if it is running good?
72luxlemans is offline   Reply With Quote
Old 02-24-2011, 10:31 PM   #2 (permalink)
you will need to run high octane in it to ward off detonation....96+ if you can get it.
Instg8ter is offline   Reply With Quote
Old 02-25-2011, 07:24 AM   #3 (permalink)
I know of a station about 20 miles away that sells 102 or 103 octane is that all I should worry about with the timing being where its at
Old 02-25-2011, 07:39 AM   #4 (permalink)
"Higher compression" is a relative term. Yes, -4s yield a little higher than -8s.
At 90 CCs, a 400 .060 over at "zero" deck (here that means .005 in the hole) will yield right at 8.8:1. No need for any "compensation" for 93 octane, should actually run well on 89.
If you have an aftermarket cam and intake, timing is a "hunt and peck" kind of thing. That is, you ned to find "the happy spot". each engine is different. Set intial at 10 BTDC and "total" at 32. Drive the car. Bump it up 2 degrees. See if it responds "better" (it should, but maybe same).
We genearlly try to keep "total" timing under 35, as Pontiac chambers a bit "too efficient" (yes, that IS possible) and are "timing sensitive". Beyond 36, we see head gaskets deteriorate rapidly. 670 heads are the "exception to the rule", as they have a "closed" chamber.
Jim
Mr. P-Body is offline   Reply With Quote
timing for 67 400 mshidner 1964-1974 GTO General Discussion 2 09-16-2010 09:52 PM
400 Pontiac with six pack nicken Engine Discussions 6 11-10-2009 04:58 PM
Timing Help on 455 Pontiac Goatman455 1964-1974 GTO General Discussion 4 06-22-2009 04:02 PM
Pontiac 400 rebuild in Seattle boatgoat 1964-1974 GTO General Discussion 2 06-15-2009 06:00 PM
400 motor timing matt68gto 1964-1974 GTO General Discussion 2 11-09-2006 09:48 AM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
