If the rebuilder is an individual and not a commercial carb builder, it may not have the damage and setup problems mentioned in my post above. When you indicated you had procured a "rebuilt" carb I assumed it was from AutoZone, NAPA, or one of the other outlets. But you should still check that carb setup for jeting to spec, correct type of float, correct float level, etc. If you want some interesting reading on Q-Jet problems, you can e-mail me for my "Q-Jet Problems" tech paper:
V8FastCars@msn.com
On a side note, I have run into several stock Pontiac iron intake manifolds that have a twist to them. These twisted manifolds will leak vacuum and never run right. But troubleshooting is easy by just squirting some starter fluid at each of the flange corners.
Lars
