Valve adjustment 69 - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 11-12-2012, 08:16 PM   #1 (permalink)
Valve adjustment 69
New to the forum. My new to me 67 has a 69 xh engine with 48 heads. I pulled the heads due to a blowback problem-unfortunately I don't see an obvious problem. When putting things back together and adjusting the valves I find that about half of the adjusting nuts bottom out before the tight plus 1/2 turn is complete. The car has been driven hard in it's history including a lot of drag racing. I put a new oem cam in the car. Could the valve stems have excessive wear? What about the rockers or pushrods. They appear stock.
Your wise counsel is appreciated.
Lrdurbin is offline   Reply With Quote
Old 11-12-2012, 09:42 PM   #2 (permalink)
joesweeting's Avatar
I had a similar issue, but just on one valve rocker bottoming out when adjusting. I had some worn parts. I don't recall what was worn/damaged since I planned on purchasing new heads. Out of curiosity, I switched some parts to change wear points and it seem to temporarly fix the problem, but I never used the heads.
Sent from my ADR6425LVW using AutoGuide.Com Free App
joesweeting is online now   Reply With Quote
Old 11-13-2012, 12:12 PM   #3 (permalink)
My Photos: (12)
If you've got stock heads, stock rockers, stock bottlneck studs, stock cam... the adjustment procedure is simple --- torque all the rocker nuts down to 20 lb.ft. They're -supposed- to bottom out.
All that changes when you start getting into aftermarket valve trains that require a fully adjustable system.
Garland, TEXAS
BearGFR is online now   Reply With Quote
Old 11-13-2012, 03:03 PM   #4 (permalink)
Thanks. I learned something
Old 11-13-2012, 06:16 PM   #5 (permalink)
My Photos: (2)
Also, use new nuts. I've had problems with re-used nuts backing off after use. Engine oil blowby is caused by worn piston rings, not valves. Worn valve guides/seals will cause oil smoke out of the tailpipe on deceleration, as in coasting down a long grade. If you have oil smoke coming from the breather cap, it's worn rings.
66' door adjustment... Instg8ter 1964-1974 Tempest, LeMans & GTO Restoration Discussions 8 03-14-2011 09:59 PM
2005 GTO LS2 valve adjustment? rnoswal Service, Maintenance and Technical Discussion 8 05-31-2009 08:18 AM
'06 Clutch adjustment? kegbelly Drive train, suspension, alignment and brakes. 7 05-01-2007 07:52 AM
04 GTO Audio Adjustment ThePrincipal Test Forum 3 01-03-2006 11:32 AM
headlight adjustment HoldenGTO Service, Maintenance and Technical Discussion 7 12-21-2005 07:02 AM
SEO by vBSEO 3.3.2
