Vibration @ 45 mph - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Go Back   Pontiac GTO Forum > The 1964-1974 Pontiac Tempest, Lemans & GTO > 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 04-14-2011, 09:44 PM   #1 (permalink)
Vibration @ 45 mph
Guys, I just had the rear end rebuilt and a new tranny installed. Took it out for a test run a discovered a pretty good vibration beginning at about 40 mph in fourth gear. I'm thinking maybe having the driveshaft balanced ?? Any thoughts on this would be greatly appreciated. Thanks.
wlbuckles is offline   Reply With Quote
Old 04-15-2011, 12:13 AM   #2 (permalink)
if it didnt vibrate before its probably connected to the work you did. did you replace ujoints?
freethinker is offline   Reply With Quote
Old 04-15-2011, 09:36 AM   #3 (permalink)
My Photos: (3)
Such as Yoke indexing, pinion angle, U joint not seated properly in yoke, loose x-mission mount.....lots of little possibilities....
Eric Animal is offline   Reply With Quote
Old 04-15-2011, 09:03 PM   #4 (permalink)
please explain Yoke indexing, pinion angle and x-mission mount. Thanks.
Old 04-15-2011, 09:12 PM   #5 (permalink)
yoke indexing is not relevant on a one piece driveshaft unless you have cut it and welded the ends back in out of plane. its a factor in 2 piece driveshafts like some trucks have. pinion angle is the difference in the angle of the driveshaft and what it connects to. you dont want it dead straight or too much of an angle. shouldnt be a factor unless you jacked the cat up or put in a different housing.
did it vibrate before? i would look hard at the work you performed.
Old 04-16-2011, 01:59 PM   #6 (permalink)
My Photos: (12)
Check the u joints on the axle end of the shaft and make sure they're fully seated into the cups on the yoke and centered. Also make sure that the bearing cups on the ends of all 4 parts of the joint cross are of the same type - either "innies" (snap rings on the inside edges of the cups) or "outies" (snap rings on the outsides of the cups). If that's not it, then the next thing to check is drive line angle (sometimes referred to as pinion angle but that's somewhat misleading with regard to what you're actually doing).
That's my prime suspect since you said "new tranny". You have to make sure that the centerline through the crankshaft/transmission runs exacly parallel to the centerline through the rear axle pinion, otherwise you'll get a vibration like the one you're describing. Please notice I said "parallel to", not "directly in line with". You don't want the centerlines in a straight line with each other because that will stop the u joints from moving at all and they'll eventually fail due to brinelling on the cross ends. Here's a link to a graphic that shows what you're trying to acheive: http://www.4x4wire.com/tech/pinionangle/stdgd.gif , and another description here: http://www.markwilliams.com/driveshafttech.aspx
Keep in mind that the lines have to be parallel in both directions: both "up and down" (as viewed from the side) and "side to side" (as viewed from the top).
You'll need an angle finder to measure it - there are several types - here's one. If yours is "off", chances are that the wrong rear transmission mount was used or there's something else "different" about the tail of the tranny/crossmember. Correcting the angle if it's off will require either changing/modifying some of those parts, or installing a set of adjustable UPPER rear control arms - like these perhaps.
Garland, TEXAS
BearGFR is offline   Reply With Quote
Gear in this thread - Powered by O'Reilly Auto Parts
60 mph vibration rod collins 1964-1974 Tempest, Lemans & GTO General Discussion 10 01-15-2011 11:42 AM
Slight Vibration? ctdkid Drive train, suspension, alignment and brakes. 4 10-17-2009 10:15 AM
A4 Vibration Noise hardball75006 Drive train, suspension, alignment and brakes. 0 11-05-2006 10:49 AM
Speaker Vibration GM Kid 2004-2006 GTO General Discussion 8 09-18-2006 06:38 PM
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
