Go Back   Pontiac GTO Forum > Supporting Vendors > Discount Tire Direct
Old 05-13-2008, 04:32 PM   #1 (permalink)
Supporting Vendor
Discount Tire Direct's Avatar
Welcome to the Discount Tire Forum (please read before posting)
Hello everyone.
Thank you for visiting us on GTOForum.com.
First about posting:
1. If you have a question about price or you would like a technical question answered quickly please visit us online or call Matt at 1.888.459.4080 ext 1865. This is the fastest way to get a response from us. You can also email Matt Directly at MJohnson@discounttireco.com.
2. We are great at making suggestions to fit your needs but we need to know a few things. Please include with your question your:
*Vehicle info: year, make and model
*Your modifications that apply: suspension, brake or body mods, current wheel and tire sizes
*Your driving habits
*How you will be using this product (highway driving, racing, winter, etc.)
Providing us with this information will help us to give you the most accurate information.
About us:
Discount Tire is the largest independent wheel and tire retailer in the world. We guarantee the best price delivered on the web. We will do what we can to match or beat the competition if we aren't. We offer free mounting and balancing and if you aren't satisfied for any reason within 30 days feel free to sent them back. We also offer the industry’s best warranty, and no, it is not pro-rated. Purchase our warranty and for the life of your tire, if anything goes wrong, aside from vandalism we will replace it for FREE.
Why we are here:
We are here to help. We are here to assist you with technical questions. Do you need a tire or wheel suggestion are you torn between a few different brands and want to know which one will be best for you?
We are also here to listen, Your opinions are valuable to us and they do matter. We will from time to time post new products or products in development and we will ask you what you think. be honest, its your opinion good or bad.
We guarantee the Lowest Delivered Price for tires and/or wheels on the web. We offer free mounting and balancing on packages, and a 30-day satisfaction guarantee!
1.888.459.4080
www.discounttiredirect.com
www.myspace.com/discounttiredirect
Discount Tire Direct is offline   Reply With Quote
Old 09-01-2008, 03:59 PM   #2 (permalink)
Is it possible to put a 275/40 17 on the back of my 05 gto on 17 /10 wheels without any mods or rubbing if so what are my choices. I'm runnin the factory 245/45/17 which has a 9.65 with I'm lookin for atleast a 10" on a deep dish if possible. thanks for your time charles
05 goathead is offline   Reply With Quote
Old 09-02-2008, 01:29 PM   #3 (permalink)
Supporting Vendor
Getting a 10 to squeeze on the rear is going to be tuff. I'm not going to say its impossible but it would be tuff for a couple of reasons. GTO's (new body) all have extremely high offset requirements. Our guide recommends no wider than a 9.5" wheel for the rear with a 61-64mm offset. To get a 10" wheel to fit the rear you would need to modify the fenders or add fender flares/wide body kit to get them to fit. I would guess it would need an offset around 58mm or so but you'd need to have it measured. As for the tire size, the 275.40.17 would fit great on the rear but you wouldn't need a 10" rim for them the 9.5" would be fine and would still give you the nice footprint you are looking for. Our guide shows with a 9.5" wide wheel with a 61-64mm offset you should actually be able to get a 285.40.17 under there.
1.888.459.4080
Old 09-02-2008, 02:06 PM   #4 (permalink)
EEZ GOAT's Avatar
My Photos: (28)
Send a message via Yahoo to EEZ GOAT
why do my BF Gforce bottom out with a passenger and my toyo trs-1 did not bottom out? same size on both brand 18x8.5 38mm offset 245/40/18 on all coners
EEZ GOAT is offline   Reply With Quote
Old 09-02-2008, 02:17 PM   #5 (permalink)
Supporting Vendor
In a size 10, Nike and Addidas fit your feet different. Tires are like shoes some run bigger, some run smaller.
1.888.459.4080
Old 10-31-2008, 11:24 AM   #6 (permalink)
Northeast Rod Run's Avatar
just to let you both know (and this is from experience, not just a guess), a 10" rim can fit under the back just fine, if the offset is correct. the offset needed is a 52 (whereas the stock offset on the factory 8" rims is 48). as far as tire size goes, it depends on the manufacturer. you could possibly fit anything from a 265 to a 285 without rubbing, depending on the style of tire
hope this helps you out
Northeast Rod Run is offline   Reply With Quote
Old 10-31-2008, 11:41 AM   #7 (permalink)
Supporting Vendor
Excellent, Thank you for your additions. It is always great to hear from someone that has done it. Out fitment guide is pretty good but it can be a little conservative for a crowd like we have here. Our guide builds in some room for this... "it depends on the manufacturer".... error that can cause rubbing. Thanks again for the input.
1.888.459.4080
Old 11-02-2008, 09:58 PM   #8 (permalink)
Send a message via AIM to xbmx89
All i want to know what the best tire for the buck for a 06 GTO on 17s all stock, The one that came with the car are so horrible and dont hook up with the road very well even with traction control on.
xbmx89 is offline   Reply With Quote
Old 11-03-2008, 06:29 PM   #9 (permalink)
Supporting Vendor
It you like to push it, you will probably be able to get any tire to break loose in your GTO. That said, some will break free easier than others. The BFG's that come stock are a 400 UTQG. UTQG is a rating set by each manufacturer as determined by their own testing not by an industry standard. It tells you how hard or soft the rubber is that makes up the specific tire. It can be used to compare other tires built by the same manufacturer. If you like the smoothness and comfort of the tire but want a tire that will grip better BFG makes their G-Force Sport with a 340 UTQG. Lower UTQG's = softer tire = better grip. I should tell you though, generally speaking, the softer the tire is, the quicker they wear out. With tires there is always a trade. The G-Force Sports are a great tire for the money. While you are shopping "best for the buck" You may also want to look at the new Goodyear GT. Click on the link called "Product Details" for features and benefits. There is a lot of technology in this tire.
1.888.459.4080
Old 11-03-2008, 11:30 PM   #10 (permalink)
THANK YOU!! very helpful! i was looking at the G-Force but i dont mind low profile tires! looking to get a new set in JAN.
Identifying Tires: Production Date, Speed Rating, & Load Range GTO JUDGE Wheels and tires 0 05-10-2008 07:53 AM
GTO Forums FS/FT/WTT forums rules. *PLEASE READ BEFORE POSTING* Rukee General Classifieds 0 04-12-2008 07:20 PM
GTO Forums FS/FT/WTT forums rules. *PLEASE READ BEFORE POSTING* Rukee 1964-1974 GTO parts needed or for sale 0 04-12-2008 07:11 PM
GTO Forums FS/FT/WTT forums rules. *READ BEFORE POSTING! * Rukee 1964-1974 GTOs for Sale 0 04-12-2008 07:07 PM
Strange issue with Flat tire at Dealership. GTOtbird Service, Maintenance and Technical Discussion 7 12-30-2006 02:22 PM
