This is a response that I gave to a guy that feels solar power won't be viable till there are improvements in batteries. You guys near Mojave know all about this place.
They actually have come up with a way to store energy from the sun. Instead of using photovoltic cells to generate energy, they use collectors that focus the enegy of the sun. These are basically U shaped mirored panels. Those panels focus the suns energy onto a tube that has a synthetic oil in it. The oil can reach temperatures as high as 600 degrees. The oil is then used to generate steam. As the night progresses, output is diminished, but they can produce large amounts of power 24/7.
There is currently a facility outside of Mojave CA that is using this technology to generate power. It is able to generate 310 Megawatts from 2000 acres. This is enough power to provide electricity for a city of a little bit larger than 100,000 people.
2000 acres is just over 3 square miles. To generate enough power for 260 million people, you would need to cover 5,200,000 acres. At 640 acres per square mile, that means you would need to cover 8125 square miles of land to generate enough power for the US. Nevada has a land area of 109,000 square miles. Cover a bit less than 10% of the land area of the Nevada desert and you have all the energy the US needs.
Here's a link for you.
FPL Energy - Solar Facts
