thanks chuck, after i posted this i went to work on it and got two more out, i have 4 left the ones located at the firewall and in the door ways. im stuck on the door way bolts because the nut around it is not like the others, infact there is no nut, it is just a metal plate around the bolt. i spent around an hour and a half cutting at it and nothing, havent seen the other side to see if maybe it is just something that the previous owner put in place or a fluke. who knows, im just going to drill the bolt out and probably cut the pan out as i planned. after the body bolts is there anything else holding the body to the frame or anything i need to disconnect? im going to post pictures later tonight! thanks
i know i ask a lot of questions but im new to this bear with me
thanks
Vinny
