67 GTO engine and engine compartment paint - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Go Back   Pontiac GTO Forum > The 1964-1974 Pontiac GTO > 1964-1974 Tempest, LeMans & GTO Restoration Discussions
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 01-20-2012, 12:25 PM   #1 (permalink)
67 GTO's Avatar
Hey guys!!now that the holidays are out of the way i can finally do some work on the car. Im going to be painting most of the engine compartment/engine. First off let me ask is it okay to use a normal spray can or rattle can or does it have to be out of a air compressor with a gun for a good finish? Is there a difference? Second whats the correct matching paint for the blacks in the engine compartment and the motor? thank you in advance!The car is a 67 GTO. Albert
67 GTO is offline   Reply With Quote
Old 01-20-2012, 03:17 PM   #2 (permalink)
My Photos: (185)
Rattle can will work fine as long as its properly prepped.
Black color is 60 degree black..... Eastwood sells the black under hood paint, its a satin finish. Engine color: medium blue metallic.
NAPA also sells the under hood black its made by Martin Senor paint.
Duplicolor's medium blue is a ice color, NAPA sells it. That color is hard to find at say AutoZone.
Use an etching primer on bare metal
Before I removed the motor and painted it with a compressor, I used the duplicolor medium blue metallic.... the picture provided is the motor rattle caned with duplicolor's med blue met. I painted it with it in the car. Covered everything. Used a lot of brake cleaner and degreaser. Took some time but it held up a few years before I restored it.
President: Susquehanna Valley GTO Inc.
president@svgto.com
Public Relations Coordinator: GTOAA
publicrelations@gtoaa.org
Old 01-20-2012, 03:24 PM   #3 (permalink)
My Photos: (12)
Ratlle can paint is a little thinner so it takes more coats to get the same amount of paint film build, but you can get there either way.
Garland, TEXAS
BearGFR is offline   Reply With Quote
Old 01-20-2012, 07:53 PM   #4 (permalink)
67 GTO's Avatar
thanks guys!! keep everyone updated with pics!
engine compartment paint Logchain 1964-1974 Tempest, LeMans & GTO Restoration Discussions 12 12-08-2011 06:45 PM
Engine and Engine compartment paint? bigrc2 1964-1974 GTO General Discussion 4 08-22-2011 08:46 PM
67 engine compartment 6tee7 1964-1974 Tempest, LeMans & GTO Restoration Discussions 5 02-25-2011 06:20 PM
67 engine compartment 6tee7 1964-1974 GTO General Discussion 0 02-23-2011 10:11 PM
Engine compartment noise tomgrancher Service, Maintenance and Technical Discussion 1 08-13-2009 06:48 AM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
