67 GTO Radiator replacement size - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-08-2014, 04:42 AM Thread Starter
Got a basket case that I am doing a ground up that did not have the original radiator as part of the purchase. It is not an A/C car so it has the 15" core. I bought an aluminum unit and it is supposed to be the same size but is about an inch too tall and I can't figure out why. the manufacturer says that he has not had any previous complaints. Any ideas why? The VIN numbers are correct and the core support was not modified.
thanks
67gtoconv is offline
post #2 of 2 (permalink) Old 01-08-2014, 08:15 AM
it will stick up about an inch above the radiator support if thats what you mean, i believe i had to use the AC car lower rubber isolators.
Instg8ter is offline
Human Verification
64 GTO Radiator Tom L 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-10-2013 04:52 PM
Replacement radiator? GTOAviator 2004-2006 GTO General Discussion 5 06-25-2013 09:11 AM
67 gto RADIATOR With A\C broadway880 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 11-25-2011 08:51 AM
what size radiator busaben 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-03-2008 08:05 PM
Best Stock Size Replacement For... BlownGTO Drive train, suspension, alignment and brakes. 0 03-15-2007 05:06 AM
