69 Trans cooler line seperator - Pontiac GTO Forum
post #1 of 1 (permalink) Old 06-17-2017, 09:58 PM Thread Starter
dan woodland's Avatar
Hi all,
When I pulled my 400 for a rebuild this fell off the car... it was not installed correctly as you can see from the bent portion in the second picture it should be straight - I'm slowly making it go back to the straight position, it was at 90 degrees. Since I did not see it before it fell off the frame rail I hope someone can show me a picture or tell me what the orientation of it is when on the car. I have not been able to find a picture or anything referring to it in my documentation(I.E. book of info, restoration guide etc).
Thanks in advance for any and all assistance, Dan
*67K miles... Under Construction* :)
dan woodland is offline
Human Verification
66 Lemans trans cooler lines Lemans guy 1964-1974 Tempest, Lemans & GTO General Discussion 4 10-15-2014 07:23 PM
Trans cooler lowpro192000 Drive train, suspension, alignment and brakes. 0 06-26-2011 10:37 PM
A4 trans cooler bridogr1 2004-2006 GTO General Discussion 1 06-26-2011 02:00 PM
Trans cooler lines teamwoody72 1964-1974 Tempest, Lemans & GTO General Discussion 6 05-03-2009 06:37 AM
Trans cooler question 04 Goatman Service, Maintenance and Technical Discussion 0 09-22-2007 03:21 PM
