engine compartment black - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Go Back   Pontiac GTO Forum > The 1964-1974 Pontiac GTO > 1964-1974 Tempest, LeMans & GTO Restoration Discussions
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 12-16-2012, 01:45 PM   #1 (permalink)
67 GTO's Avatar
hey guys, got a long cold winter ahead started painting the motor last night took the A/C off and all the brackets and tons of masking. its coming right along. My question is all the black components under the the hood such as A/C brackets, alternator, fender wells,radiator support and most of the black components is it all the same 60 % gloss black?
67 GTO is offline   Reply With Quote
Old 12-16-2012, 03:32 PM   #2 (permalink)
My Photos: (473)
Yes, everything you listed including the firewall in the engine compartment is 60% gloss black except for the bottom of the hood which is 30% gloss black,
Old 12-16-2012, 07:23 PM   #3 (permalink)
67 GTO's Avatar
thank you, whats the best way to paint the items? sand it prime it and paint it or just scuff up and paint over the existing.?
Old 12-16-2012, 07:25 PM   #4 (permalink)
My Photos: (12)
Depends on how good the existing coating is. If it's in good shape, not peeling, hasn't worn through, etc. then scuff, clean, and paint should work fine.
Garland, TEXAS
BearGFR is offline   Reply With Quote
Old 12-17-2012, 10:26 AM   #5 (permalink)
My Photos: (2)
I agree with Mr. Bear. I touched up a couple small places on my '67's firewall that had peeled due to pressure washing. The original body color was underneath. I don't think they used primer under the underhood paint....So, I'd just scuff lightly and shoot. I forget what brand low-gloss paint I used, but the match was so good I can not tell where I touched it up. Ditto on the fenderwell where the battery cable rubbed the original paint. on my Baltimore built car, the gloss level is low, about 20%....not 60% on these parts. My alternator brackets, etc are higher gloss.
geeteeohguy is online now   Reply With Quote
Old 12-17-2012, 05:08 PM   #6 (permalink)
67 GTO's Avatar
Thanks Bear and geeteeoguy, in some spots the paints is peeling and the underneath is showing no major rust or anything like that on the fernderwells. The radaitor support and batter box has surface rust around those parts i was going to wire brush them andd sand than a little primer and paint. The cars never really had a "real" paint job before someone previously tapped off all the chrome and and windows and sprayed so the firewall still looks like it did from 67, orginal chalk writing on it still.
Old 12-17-2012, 05:42 PM   #7 (permalink)
67 GTO's Avatar
whats the correct blue for a 67 Pontiac 400, is it the flat blue or the metallic blue?
Old 12-17-2012, 08:23 PM   #8 (permalink)
My Photos: (473)
Your 67 block is metalic blue, here are a couple screenshots from the GTO restoration guide on some of the engine compartment paint;
The image illustration mentions 64 but applies to 64-67 for the inner fenders or splash shields;
engine compartment black-67gto-coresupport.jpg   engine compartment black-67gto-innerfender.jpg
Old 12-18-2012, 01:20 AM   #9 (permalink)
67 GTO's Avatar
thank you! thast perfect ! helped me tons!
Old 12-31-2012, 03:46 PM   #10 (permalink)
67 GTO's Avatar
is the 60 % gloss black the same as semi gloss? I cant find the 60 % but only the semi gloss
67 GTO engine and engine compartment paint 67 GTO 1964-1974 Tempest, LeMans & GTO Restoration Discussions 3 01-20-2012 08:53 PM
Engine and Engine compartment paint? bigrc2 1964-1974 GTO General Discussion 4 08-22-2011 09:46 PM
67 engine compartment 6tee7 1964-1974 Tempest, LeMans & GTO Restoration Discussions 5 02-25-2011 07:20 PM
67 engine compartment 6tee7 1964-1974 GTO General Discussion 0 02-23-2011 11:11 PM
Motor & Engine Compartment Done GOFASTGTO 2004-2006 GTO General Discussion 13 02-26-2009 09:01 PM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
