ignition switch pigtail - Pontiac GTO Forum
post #1 of 12 (permalink) Old 05-13-2017, 10:40 AM Thread Starter
wanted ignition switch pigtail for 1965 GTO w/o air
spiker is offline
post #2 of 12 (permalink) Old 05-14-2017, 10:42 AM
when I compare the back of the 64-65 switch to the 66-67 switch, it looks like the pigtail would be the same, except there is an extra wire \contact on the switch \ pigtail for AC which you would just not use in a Non AC car. So if you could, please photograph the back of your switch so I can confirm if I have the right pigtail for you. thanks
pontiac is offline
post #3 of 12 (permalink) Old 05-15-2017, 08:23 AM
lil65gto's Avatar
Spiker, I don't mean to highjack your post but I too have the same dilemma. Just this past Friday I have talked to Painless wiring, American Autowire and M&H Wiring (they supply the harnesses to Ames) for this pigtail. In fact, when I called Ames...they stated they get at least a call a week for this pigtail. All the companies I spoke to said they get calls all the time for this but they don't sell just the pigtail. I wish I could get my hands on a good plastic connector as I would mold this and repop it myself.
lil65gto is offline
post #4 of 12 (permalink) Old 05-15-2017, 10:57 AM
okay, so photo the switch and we can go from there. Thanks. My switches are all loose and I am not sure which is for what year, so your photo will tell me. Thanks
pontiac is offline
post #5 of 12 (permalink) Old 05-15-2017, 04:34 PM Thread Starter
Here is the picture
spiker is offline
post #6 of 12 (permalink) Old 05-16-2017, 04:49 PM
so it seems that the back of the 64-65 and the 66-67 tempest ignition switches are the same, all 6 connectors match. When they had AC, there would have been an extra connector (a ground actually) in addition to the one ground connector already on the 6 connector back. So one could take a non AC switch and use it on an AC car if they jumped the one ground into the second ground wire on the AC pigtail.
now the 6 connector (non AC) pigtail will fit all 4 switches, it fits on fine and does not interfere with that 7th AC connector. There would just not be any wiring going to that 2nd ground connector on the 7 terminal AC switch.
That pigtail shown is the only one I have but if lil65gto can repop it for all of us, I would consider loaning it or maybe getting a digital scan? so it could be 3D printed. PM me if you have any ideas. Hope this helps.
ID:	90801   Click image for larger version
ID:	90809   Click image for larger version
ID:	90817   Click image for larger version
ID:	90825   Click image for larger version
pontiac is offline
post #7 of 12 (permalink) Old 05-16-2017, 04:52 PM
one more photo
pontiac is offline
post #8 of 12 (permalink) Old 05-17-2017, 08:34 AM
lil65gto's Avatar
I acquired a nice switch connector Monday night from a '64 GTO. Currently waiting on materials to make the rubber mold (I'm old school...no 3d printer here). Probably going to wish I had a 3d printer before I'm all said and done. I've cast and poured a ton of items over the years but this one is going to be a challenge as I'm trying to figure out how to cast all 6 of the electrical connector slots perfectly. I'll update with results.
Name:	Ignition Switch Connector.jpg
lil65gto is offline
post #9 of 12 (permalink) Old 05-25-2017, 06:52 AM
lil65gto's Avatar
Success...
Iíve made a few now and they work. I have to learn patience to not demold too early as it distorts the fresh plasticÖlol. Iíll have to order up liquid black plastic as all I have in stock is white (I could paint them but they are out of sight). Wire connectors snap positively into the slots and hold like the original. I didnít mold the hooks as it would have been a PITA to make a 3 pc mold for them. I might make a secondary mold that would be utilized to remold the hooks onto the previously made connector but as of right nowÖthe fit is great to the ignition switch.
Name:	Ignition Switch Compilation.jpg
lil65gto is offline
post #10 of 12 (permalink) Old 05-25-2017, 09:51 AM
what would you think about doing the one with the seven prongs for the AC switch? That way the one 7 prong connector could be used for either the six or the 7 connector switch? PM me and I can find you a 7 prong pigtail as a model. Thanks, it looks good.
pontiac is offline
  Pontiac GTO Forum > Buy / Sell / Wanted (1964-1974) > 1964-1974 GTO's and Parts Wanted
Human Verification
1965 Ignition Switch Pigtail + Plug source? CP-Mike 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-11-2014 11:01 PM
68 Ignition Switch kilkm68 1964-1974 Tempest, Lemans & GTO General Discussion 1 06-28-2014 08:57 AM
67 Ignition switch lam63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-13-2012 02:44 AM
65 ignition switch asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-25-2009 11:58 PM
Ignition Switch? 66_goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 10-29-2007 10:13 PM
