1965 GTO Manual Transmission fluid change - Pontiac GTO Forum
post #1 of 1 (permalink) Old 05-03-2016, 12:32 PM Thread Starter
I'd greatly appreciate advice on changing the transmission fluid in my 1965 GTO manual transmission. The car has been sitting for a period of time and when I drove it recently, I heard noise (grinding sound) at the top end in all gears. I'm hoping this is a simple fix - adding transmission fluid.
I don't intend to do this myself. I've read something about the drain plug having to be removed, fluid drained, and then the plug having to be replaced with some type of adhesive/glue.
Can someone please give me some advice on this procedure and what type of fluid would be best suited for this 4-speed?
Thanks!
David
Dave389 is offline
Change Automatic Transmission Fluid and Filter iwant2buyaGTO Service, Maintenance and Technical Discussion 8 08-16-2014 04:58 PM
Automatic Transmission fluid change/details Rgrafton Service, Maintenance and Technical Discussion 5 04-09-2014 04:00 PM
What Manual/T56/M12 transmission fluid is everyone using? bigdeezs Drive train, suspension, alignment and brakes. 5 03-27-2014 11:10 AM
Manual Transmission Fluid Location KroBeast13 Service, Maintenance and Technical Discussion 15 06-30-2011 07:18 PM
