1966 Blower motor - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-23-2015, 06:03 PM Thread Starter
1966 Blower motor
Just finishing up on a frame off restoration on a 1966 GTO, auto,factory A/C, electric windows, PS,PB, thaat I picked up last summer. After refurbishing the dash clusters, and getting the engine running, I realized that the heater/AC blower failed to work on either "HEAT or "DEICE". It worked on all the other settings. After spending all day removing the control unit, I discovered that an arm that slips into a detent on the round controler was bent. After straightening the arm, I tested the unit while it hung outside of the dash. All settings seemed to work fine, so I reinstalled everything, only to find that now the blower doesn't work in any position at any speed. The really odd thing is that the blower is getting power, 11.9 volts. I have 12.1 volts at the battery, an acceptable loss I thought. But when I run a jumper wire directly from the battery to the blower, it works fine. This doesn't make any sense, and I am hoping that someone can help. All fuses are good, and I can hear the relay clicking. The resistor and relay are new.
aahrested is offline
post #2 of 2 (permalink) Old 03-26-2015, 09:06 AM
You probably want to post your question in the Tech Discussion section of the forum. Matt
Matthew is offline
68 blower motor help joedee 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-31-2013 09:35 PM
blower motor 68GTO4004Spd 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 02-21-2011 08:14 PM
1972 where's the blower motor? jeremymac 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 09-01-2010 02:06 AM
Heater Blower Motor Joshua42007 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 05-05-2009 10:50 AM
