1970 gto turn signals - Pontiac GTO Forum
 1Likes
  • 1 Post By tallen4392
post #1 of 3 (permalink) Old 08-23-2016, 06:31 PM Thread Starter
HI i have a tough one 1970 gto turn signals only work on right side of car. when left is on dont work but you can hear the new flasher going very fast.. but no signals or indicator light on dash i put in new turn signal switch new bulbs.. the strange thing is when i turn on parking lights they will work very fast and the reverse light also flashes along with with the dash lights the right side no problem i checked the grounds also any ideas at all...thanks
Pinion head likes this.
tallen4392 is offline
post #2 of 3 (permalink) Old 08-24-2016, 11:49 AM
Red1970GTO's Avatar
Electrical issues can be a real Hillary Rodham and what you describe is almost always due to a bad ground. The turn signal system is a hot system so get out your electrical checker and start checking grounds (again). My advise is to recheck everything.
> Make sure you have the correct bulbs (BTW: LED bulbs require an LED flasher).
> Make sure you have the correct flasher.
> Make sure the connections are all clean (you can purchase dielectric grease at your local auto parts store to improve the connections).
Bulbs lighting when they're not supposed to (i.e. Your reverse light) is a clear indication of a bad ground. There are ground wires in the trunk area as well as the front bumper area. The first ground I like to check is the one in the trunk that attaches to the trunk latch support.
"Honest Honey, it just kinda followed me home, can I keep it?"
Red1970GTO is offline
post #3 of 3 (permalink) Old 08-24-2016, 06:53 PM Thread Starter
Thanks for the info i checked the grounds in the trunk all ok when you say the correct flasher i did not think there were choices i grabed the 2 prong flashers from napa are there different ones let me know please when the left blinker is on the flasher gets very very hot thanks again
No turn signals/brake lights 65 GTO Tiptonte 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 05-16-2013 07:18 PM
turn signals Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 14 07-13-2011 08:21 AM
'68 turn signals 68greengoat 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-05-2011 09:18 PM
68 GTO Dash Lights/ Turn signals not working 911turboz 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 08-04-2009 03:28 PM
help with turn signals HoldenGTO Service, Maintenance and Technical Discussion 4 01-19-2006 06:15 PM
