66 GTO Convertible / Correct Battery Size - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-16-2014, 11:08 AM Thread Starter
jgotzens's Avatar
I have a 66 Convertible. Just got it recently and it starts and idles fine, but when it first starts there is a hesitation, then it fires up, almost as it needs more juice to get going. It is a 389 tri power. Battery shows 12.6 volts before starting. Battery is 670 CCA. Is that enough?
jgotzens is offline
post #2 of 3 (permalink) Old 07-16-2014, 01:35 PM
That should be enough battery. If when cracking it's hesitating (crankshaft stopping or almost stopping) then it sounds like the timing might be too far advanced. I have to retard my timing from normal settings with the lower octane fuels we have now.
post #3 of 3 (permalink) Old 07-16-2014, 02:04 PM Thread Starter
jgotzens's Avatar
Thanks Rukee. I think you nailed it. I just advanced the timing some and it seemed to be running OK. No diesling but there is a bit too much "clunk" shifting. I was going to back it down. It's around 6 now.
jgotzens is offline
Best tire size for 15x7 on 67 convertible MrT 1964-1974 Tempest, Lemans & GTO General Discussion 7 08-31-2013 08:29 PM
I need help in picking the correct fuel line size for 68 GTO tocagao 1964-1974 Tempest, Lemans & GTO General Discussion 10 04-11-2013 09:04 PM
What style battery cable is correct? 70conv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 07-16-2012 11:11 AM
Correct size for 66 gto speedometer?? Mr66GTO 1964-1974 Tempest, Lemans & GTO General Discussion 0 05-03-2009 08:37 PM
