Hood latch mystery - Pontiac GTO Forum
post #1 of 1 (permalink) Old 02-28-2019, 11:54 AM Thread Starter
Hood latch mystery
I recently purchased a 65 GTO that someone else disassembled and then he had some less than proficient people work on in reassembly. The rear-most hood latch ( not safety latch) which bolts on from underneath the header panel has the release lever at around the 10:00 position. This captures the latch lever between the radiator and the front sheet metal between the grills, making it impossible to access. I suspect it's installed wrong or possibly the wrong latch, but have been unable to find an assembly diagram on-line that shows the proper position. Is there supposed to be an under-dash hood release cable that attaches to this lever? Does anyone have a diagram they an share or short of that, a body panel assembly manual they can recommend? I have the 65 Tempest Chassis manual that came with the car, but it does not cover details like this.
Thanks!
ronayers1965 is offline
hood latch spring Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 11-18-2010 10:25 PM
Hood Latch on a 65 injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 24 04-22-2010 11:01 AM
Hood Latch Fell Off! Goatman455 1964-1974 Tempest, Lemans & GTO General Discussion 14 06-12-2009 11:02 AM
1967 GTO Hood Latch Assembly nevermind8285 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 01-25-2009 09:48 PM
Hood latch lever busted? MahGoat 2004-2006 GTO General Discussion 9 06-23-2008 12:55 AM
