Initial Start Up Problems - Pontiac GTO Forum
post #1 of 1 (permalink) Old 05-23-2018, 10:52 AM Thread Starter
Just got my 1966 GTO with a 455ci bored .030 over, pro-charger (8lbs boost) put back together. I have a demon GT 750 carb. Tried the initial start up on it and "wants" to run but won't stay running. The ignition is from MSD Ready to Run and the coil is as well (Blaster 3) new plugs and the wires are Fire Core Ignition Wires by Rick Gorski. I had a machinist put in -22 pistons, valves cleaned, Mahle Pistons and rings and a Eagle crank. Firing order is correct with the specs. Any assistance? Did a bypass for the coil as well to help push more juice...Thanks MAD DOG In Rineyville, Ky
MAD CAV SCOUT is offline
60 degrees of initial advance?? 65Poncho 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 36 04-07-2017 08:51 PM
Initial Timing Setting NEEDLEZ 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 07-21-2015 01:43 PM
Cold start problems with rochester quadrajet. Fuel draining out of carb ? dillon14 1964-1974 Tempest, Lemans & GTO General Discussion 8 07-15-2011 11:55 PM
Radio Problems and remote start issues. dcoen21 Service, Maintenance and Technical Discussion 3 09-06-2009 07:48 AM
69 Hard start problems 69Goat4fun 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 05-25-2009 01:17 PM
