muncie m20 hard shifting - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-19-2014, 10:27 PM Thread Starter
My 66 gto shifts fine at normal speed but under power 2nd to third and third to fourth shifts hard and grinds any ideas thanks
mikey9743 is offline
post #2 of 2 (permalink) Old 09-20-2014, 02:36 PM
rickm's Avatar
Quoted: 5 Post(s)
im no Muncie expert, but I would first make sure clutch, shifter, n stop bolts are adjusted correctly. also check that all clutch components function the way they should before the thought of an internal problem in the transmission.
rickm is offline
Muncie M20 transmission mysons69 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 14 05-12-2017 12:41 PM
What's the difference between a M20 and M21 Muncie 4-speed? extinctmake 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 03-14-2012 11:26 AM
Muncie Transmission Question about an M20 Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 8 09-03-2011 12:16 PM
Help with Muncie M20 info: New Member Mark M 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 10-06-2010 01:00 PM
