Soft brake pedal and Wobble in new rear disk rotor - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-30-2017, 02:07 PM Thread Starter
I have a 1967 lemans that I converted to disk front and back. I replaced all of the components, master cylinder, brake lines, booster, front and back disks. Started by bleeding the master cylinder. Bleed all of the lines starting form pass rear, driver rear, pass front and then driver front. After bleeding the brakes have a soft pedal. I swapped out the rear bleeders with the self bleeding so that I could bleed them myself and spent hours bleeding them but still has a soft pedal. Not sure if this is part of the problem but I am seeing a lot of rotor wobble which could be causing the soft pedal and am getting a dial indicator to confirm if this is from the hub or rotor. My question in regards to the rotor wobble is if I find it is the hub how would I go about correcting this problem. Any help would be appreciated.
Thank you
RM9700 is offline
Disc brake rotor wobble HELP! Dealer369 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 04-30-2017 06:45 PM
front brake rotor Topkat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 06-27-2014 03:59 PM
Soft clutch pedal johni53 Service, Maintenance and Technical Discussion 3 12-06-2012 10:32 PM
66 lemans disk brake ?'s 66ohc 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 11-09-2012 07:40 AM
front disk brake rotor question matt68gto 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 02-09-2007 08:03 AM
