Transmission Vacuum Line Help! - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-04-2014, 07:46 PM Thread Starter
Familytradition's Avatar
I have a 66 gto convertible with a 389 2 speed transmission. I just got the car and found out that the transmission vacuum line is been hacked. I'm not sure how or where it goes other than it connects to the transmission and somewhere on the four barrel carburetor. I just picked up what I thought was the correct line from Ames performance....no idea how this is to work, the bends look all wrong. If anyone has an info please help...If you have pictures please send them. I'm lost. thanks
Familytradition is offline
post #2 of 2 (permalink) Old 10-13-2014, 12:59 AM
646904GTO's Avatar
it just plugs into a manifold vacuum port. Most likely it is plugged now so look for it. The tube should end up close to it if connected correctly to the modulator valve.
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
67 gto vacuum line question Gramps 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 03-14-2018 04:36 PM
Vacuum Line Connections Thurber73 1964-1974 Tempest, Lemans & GTO General Discussion 9 08-14-2014 07:57 PM
68 Vacuum line hook up Question keoni1978 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 01-31-2014 04:23 PM
Vacuum modulator line routing FlambeauHO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-11-2013 05:07 PM
64 GTO vacuum line diagram greengrad1977 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-01-2010 08:58 PM
