Pontiac GTO Fog Light LED Bulbs! USA Made SLF Model! Plug & Play Install! - Pontiac GTO Forum
post #1 of 25 (permalink) Old 10-16-2015, 09:50 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Arrow Pontiac GTO Fog Light LED Bulbs! USA Made SLF Model! Plug & Play Install!
(G8 used as comparison)
Diode Dynamics carries LED bulbs for replacement of your Pontiac GTO's fog lights, in all major sizes. They are available in HP, XP, and SLF styles.
Just simple plug and play, replace the bulb and you are good to go!
Diode Dynamics offers the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
Brightness:
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
SLF: Street Legal Output. Much brighter than factory. These are bright! USA Made!
Bulb Design:
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Pontiac GTO).
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 2004-2006 Pontiac GTO
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics is online now
post #2 of 25 (permalink) Old 03-24-2016, 03:59 PM Thread Starter
Supporting Vendor
Customer Submitted photo with Yellow XML2 Installed
Nick C.
post #3 of 25 (permalink) Old 01-29-2018, 11:49 AM Thread Starter
Supporting Vendor
Curious to see how the new Diode Dynamics, USA-Made, SLF performs in fog light locations? (2015+ F150 shown for comparison)
post #4 of 25 (permalink) Old 02-28-2018, 11:01 AM Thread Starter
Supporting Vendor
Why Do Yellow LEDs Look Green? | Yellow LED Fog Lights from Diode Dynamics
post #5 of 25 (permalink) Old 03-01-2018, 11:19 AM Thread Starter
Supporting Vendor
Diode Dynamics SLF Fog Light LEDs
post #6 of 25 (permalink) Old 03-26-2018, 09:09 PM Thread Starter
Supporting Vendor
post #7 of 25 (permalink) Old 04-04-2018, 05:42 PM Thread Starter
Supporting Vendor
Please feel free to give us a call with any questions you may have: (314) 205-3033
Thank you!
Nick C.
post #8 of 25 (permalink) Old 04-11-2018, 03:45 PM Thread Starter
Supporting Vendor
Diode Dynamics SLF LED Fog Lights / USA Made
post #9 of 25 (permalink) Old 04-23-2018, 05:21 PM Thread Starter
Supporting Vendor
Don't forget to send us a PM for the free-shipping code!
(U.S. addresses only)
Nick C.
post #10 of 25 (permalink) Old 04-24-2018, 07:38 PM Thread Starter
Supporting Vendor
PM responses sent!
  Pontiac GTO Forum > Vendors > Diode Dynamics
Pontiac GTO Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day! Diode Dynamics Diode Dynamics 31 10-23-2019 05:01 PM
Pontiac GTO LED Conversion Kit! Upgrade your lighting! Plug & Play Install! Diode Dynamics Diode Dynamics 26 10-23-2019 04:12 PM
Pontiac GTO Turn Signal LEDs! Plug & Play Install! No "Hyperblink" w/Flasher Module! Diode Dynamics Diode Dynamics 15 10-23-2019 04:10 PM
Pontiac GTO License Plate LEDs! Plug & Play Install! Same day Shipping! Diode Dynamics Diode Dynamics 22 10-23-2019 04:07 PM
Dashboard issue with tail light LED install 6LGTO Interior Discussions 6 08-28-2014 09:57 PM
