Pontiac GTO License Plate LEDs! Plug & Play Install! Same day Shipping! - Pontiac GTO Forum
post #1 of 23 (permalink) Old 10-16-2015, 09:26 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Lightbulb Pontiac GTO License Plate LEDs! Plug & Play Install! Same day Shipping!
License plate bulbs are used to illuminate the rear license plate on your GTO. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your GTO!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your GTO looks at night.
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
Brightness:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design:
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Pontiac GTO).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
2004-2006 Pontiac GTO License Plate LEDs
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 23 (permalink) Old 03-25-2016, 10:12 AM Thread Starter
Supporting Vendor
Originally Posted by lannym View Post
Do you sell LEDs for other areas of the car?
We have a complete listing available for the GTO here on our site: Pontiac GTO LED and HID Lighting
The LED options are listed by location, to make it easy to find
Feel free to give us a call if you have any questions: (314) 205-3033
Thank you!
Nick C.
post #3 of 23 (permalink) Old 03-25-2016, 04:29 PM Thread Starter
Supporting Vendor
Excellent! Thank you for checking out our site
We appreciate your support
Nick C.
post #4 of 23 (permalink) Old 03-08-2018, 10:00 AM Thread Starter
Supporting Vendor
Bulb dimensions are being added to our listings to help customers confirm fitment for unique applications.
Thanks!
post #5 of 23 (permalink) Old 03-26-2018, 12:08 PM Thread Starter
Supporting Vendor
post #6 of 23 (permalink) Old 04-04-2018, 07:47 PM Thread Starter
Supporting Vendor
Please feel free to give us a call with any questions you may have: (314) 205-3033
Thank you!
Nick C.
post #7 of 23 (permalink) Old 04-23-2018, 10:26 AM Thread Starter
Supporting Vendor
Don't forget to send us a PM for the free-shipping code!
(U.S. addresses only)
Nick C.
post #8 of 23 (permalink) Old 04-26-2018, 12:06 AM Thread Starter
Supporting Vendor
(314) 205-3033
post #9 of 23 (permalink) Old 04-30-2018, 10:07 AM Thread Starter
Supporting Vendor
Behind the LEDs: Trevor Dobbins
post #10 of 23 (permalink) Old 05-01-2018, 09:21 PM Thread Starter
Supporting Vendor
(314) 205-3033
  Pontiac GTO Forum > Vendors > Diode Dynamics
Pontiac GTO Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day! Diode Dynamics Diode Dynamics 31 10-23-2019 05:01 PM
Pontiac GTO LED Conversion Kit! Upgrade your lighting! Plug & Play Install! Diode Dynamics Diode Dynamics 26 10-23-2019 04:12 PM
Remote controlled motorized hideaway license plate frame: $10 off plus free shipping! PFYC Exterior Discussions 0 02-08-2013 04:42 PM
Free Shipping on Show N Go Motorized License Plate Frames @ PFYC.com PFYC Exterior Discussions 0 09-06-2012 02:17 PM
Free Shipping on motorized Show N Go retractable license plate brackets at PFYC.com PFYC Exterior Discussions 0 07-14-2011 09:46 AM
