`68 wiper switch - Pontiac GTO Forum
post #1 of 14 (permalink) Old 10-09-2013, 05:12 PM Thread Starter
`68 wiper switch
Okay, so I swapped out the under dash and under hood wiring harnesses and ever sense the wipers don't park right, they just keep going up and down about 4 inches trying to park till they finally do park. The old harness had the two wire plug at the motor attached to the bottom two posts and a single wire at the top. In order to get them to park right I had to put the single wire on the bottom and flip the two wire plug upside down from what it was originally. So after messing around and finally got it to work right by switching the wires, but it reversed the wiper switch. At park before the word washer on the knob was orientated level and turned counterclockwise to turn them on. Now it turns clockwise to turn on and when off the word wiper is at a 90* angle from being flat, but it does park the first time. Both speeds work right and it parks right, but the switch looks like it's turned on. WTF?
post #2 of 14 (permalink) Old 10-10-2013, 08:11 AM
First off, are you sure you have a '68 wipe switch? When I was putting my '69 together my wipers were doing some very strange things too. I finally figured out that I'd installed a '70 wiper switch. Externally, it looked identical to the '69 switch but it sure didn't work the same from an electrical standpoint.
post #3 of 14 (permalink) Old 10-10-2013, 09:00 AM Thread Starter
No not positive it is a `68 switch. This is the switch in it's new "off" position.
post #4 of 14 (permalink) Old 10-10-2013, 02:44 PM Thread Starter
Anyone with a `68 wanna chime in on which way your wiper switch works? And maybe which way your 3 wires attach to the wiper motor?
Also, where is the reverse switch at?? On the `65 it's on the trans, but not on this one, or is it just missing from the trans?
post #5 of 14 (permalink) Old 10-11-2013, 09:26 AM Thread Starter
anyone?
post #6 of 14 (permalink) Old 10-11-2013, 10:55 AM
Ruckee, are you asking about the back up light switch? If so, on the manual transmission it is mounted directly behind the reverse link rod on the shifter. I will go out and look at the wiper motor in a bit. Matt
Matthew is offline
post #7 of 14 (permalink) Old 10-11-2013, 11:24 AM
Ruckee, my wiper motor has the single wire connected at the top (black/blue). Double wire connector below that (black/yellow on top black/white on bottom). Pump has a double wire connector (blue/white on left and black/yellow on right). Matt
Matthew is offline
post #8 of 14 (permalink) Old 10-11-2013, 11:36 AM Thread Starter
Thanks Matthew, I'll check that out this afternoon and report back.
post #9 of 14 (permalink) Old 10-11-2013, 11:39 AM
Yes sir, Matt
Matthew is offline
post #10 of 14 (permalink) Old 10-11-2013, 11:48 AM
68GTO4004Spd's Avatar
Sorry I can't help you out Rukee, I have to leave mine unplugged all the time because it won't park and I have never taken the time to figure it out. I still haven't even aimed my headlights. Needless to say, the car never sees rain or dark.
68GTO4004Spd is offline
Modern Windshield Wiper Arms & Switch Indecision 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 5 05-07-2011 03:28 PM
64 wiper switch wiring homer43 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-01-2010 11:55 PM
help!!..65 wiper switch oldgoat651967 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-05-2010 01:08 PM
