'06 GTO seats in a '67 - Pontiac GTO Forum
post #1 of 20 (permalink) Old 07-14-2012, 09:45 AM Thread Starter
GTOKIDRH's Avatar
I have a '67 Goat and just purchased an interior from a '06. I am going to use the seats in the '67. Can anyone give me any info and or pics to accomplish this? I know it has been done and i am especially interested in the rear seat. The fronts shouldn't be too hard but any advice would be appreciated.
GTOKIDRH is offline
post #2 of 20 (permalink) Old 07-14-2012, 05:20 PM
rickm's Avatar
Quoted: 5 Post(s)
dont do it. '64-'67 have the NICEST stock interiors of all gtos...
rickm is offline
post #3 of 20 (permalink) Old 07-15-2012, 09:24 AM
ppurfield001's Avatar
I really like the '05 GTO seats in the front of my 1967 GTO. However, I didn't bother with the rear seat -- too much trouble fitting it properly. Good luck.
ppurfield001 is offline
post #4 of 20 (permalink) Old 07-15-2012, 09:28 AM
, But if you are gonna do it....my interior will be done in about a week...I will post pics then. IF you like my job, I can probably get the Upholstery shop to modify your rear seat.....this is the hard part. The front seats fit well, with a mod to the tracks. Rears need major fabrication to look right.......alsp see CRUSTYSACK's build. Eric
ID:	15262   Click image for larger version
ID:	15263   Click image for larger version
ID:	15264   Click image for larger version
ID:	15265   Click image for larger version
Eric Animal is offline
post #5 of 20 (permalink) Old 07-21-2012, 03:24 PM
crustysack's Avatar
Although the 64-67 are the "nicest", by todays standard they are downright uncomfortable,
the fwd tracks of the 06 seats need to have the rear tabs ground off, you need to fabricate custom mounts in the floor. I just made a base with a 5/16 stud welded to the floor. You can use the stock fwd inboard stud to locate the seat and it will be centered with your steering wheel, and then set the other 3 points. I am 6'1 and have a really comfortable pedal and steering wheel reach with this set up. The rear poses a different problem, the 06 seat is much narrower and taller than the old one, so you either set it place and fill in the outer sides with upholstered pieces- about 5-6" wide. But this looks funny because the front and rear seats dont line up, so I split the rear seat and mounted them directly behind the fronts and made a wider center console/ sub woofer enclosure. The height issue can be addressed by having the round piece that goes around the headrest removed and just leaving the headrest in (for safety) or leave the headrest out for the old school look. I think the 4 bucket seats look good though. search my interior posts and you will see
crustysack is offline
post #6 of 20 (permalink) Old 07-21-2012, 06:15 PM Thread Starter
GTOKIDRH's Avatar
Any pics of your seats Crustysack?
GTOKIDRH is offline
post #7 of 20 (permalink) Old 07-22-2012, 08:39 AM
crustysack's Avatar
heres the post of almost finished interior https://www.gtoforum.com/f83/65-gto-c...nterior-32490/
the first pic has the rears with no headrests but I have them in now
post #8 of 20 (permalink) Old 07-22-2012, 09:04 AM
Crusty, When you 'widened the back seat', did you still need fillers between the seats and the rear quarter panels?.....mine is "in progress as we speak. Thanks, Eric
post #9 of 20 (permalink) Old 07-22-2012, 09:07 AM
Also......did you guys see the 64 GTO in the new High Performance Pontiac Mag??? The owner mounted 2 front buckets in the back ....looks like a 2+2 set up......extremely cool mods on the car, in and out....Eric
post #10 of 20 (permalink) Old 07-22-2012, 06:38 PM
crustysack's Avatar
yes I made filler pieces for the side to cover up the exposed floor and rear brace, they were about 2 1/2 - 3" wide and they mount kind of under the seat sides just to blacked out those spots
06 Seats Into a 72 GTO AGETECH 1964-1974 Tempest, Lemans & GTO General Discussion 16 02-20-2014 09:33 PM
04-06 GTO seats ponchonorm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 01-15-2011 08:59 PM
different seats mp4life23 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 09-17-2010 11:24 PM
Possible 68 GTO seats?? Halsey 1964-1974 Tempest, Lemans & GTO General Discussion 13 09-05-2010 05:05 PM
