06 Seats Into a 72 GTO - Pontiac GTO Forum
post #1 of 17 (permalink) Old 07-02-2012, 04:21 PM Thread Starter
I heard they were too tall, too wide, too heavy, and you loose headroom & legroom. Its NOT TRUE. I just put these into my 72 and I can't believe how comfortable they are, and how they hold you in the car. Two wire power hook-up and they work great, there is a lot of adjustment in these seats. I am in the process of changing my interior to black, these were way cheaper than recovering my old seats.
Legroom: Does not change front or rear, depends on your adjustment.
Weight: I did not put them on a scale, I did lift in & out of car, same weight.
Height: Seating area is lower at lowest setting by 1.5in.
Headroom: Lost .5in, probably due to firmer seat.
Width: Same
Here are some pics, brackets are simple 1/8 steel, seats are very solid after mounting. Flat brackets are front, bent brackets are rear.
ID:	15184   Click image for larger version
ID:	15185   Click image for larger version
ID:	15186   Click image for larger version
ID:	15187   Click image for larger version
AGETECH is offline
post #2 of 17 (permalink) Old 07-02-2012, 06:13 PM
Send a message via Skype™ to Jackanapes
Wow... I like that. I would guess it would be the same for a 68?
Jackanapes is offline
post #3 of 17 (permalink) Old 07-02-2012, 07:34 PM Thread Starter
I think it would be the same, I could get dimensions for brackets if anyone needs them.
AGETECH is offline
post #4 of 17 (permalink) Old 07-02-2012, 10:02 PM
1967 GTO. At upholstery shop now. 2006 Red buckets...having headliner an door panels done to match. 1968 should be the same.
ID:	15189   Click image for larger version
Eric Animal is offline
post #5 of 17 (permalink) Old 07-03-2012, 04:26 PM Thread Starter
Those seats change the way whole car feels, like you are actually in charge.
AGETECH is offline
post #6 of 17 (permalink) Old 07-04-2012, 08:05 AM
ppurfield001's Avatar
Width: Same
If you're a resto-mod guy, the newer seats work. I have 2005 seats in my 1967 GTO.
ppurfield001 is offline
post #7 of 17 (permalink) Old 07-04-2012, 08:30 AM
with "Shorty" Purfield...You could also have them re-upholstered to MATCH the GTO interior....expensive, but worth it if it fits your budget.
post #8 of 17 (permalink) Old 07-08-2012, 04:18 PM
crustysack's Avatar
I was also told that the 06 seats would not fit my 65- but I am stubborn and with some minor fabrication they fit like a dream. The newer seats make me feel like a baby in a papoose( being dragged by wild horses) and then I threw the rears in to match
crustysack is offline
post #9 of 17 (permalink) Old 07-08-2012, 05:36 PM
Dunnburger's Avatar
Crusty, you have any photos or your seat install? I've got a 65 as well and thinkin about going with "new" seats rather than having mine re-covered.
Dunnburger is offline
post #10 of 17 (permalink) Old 07-08-2012, 06:13 PM
I will post some pics of my interior install when it comes back from the Upholstery shop.....hopefully by next weekend Eric
04-06 GTO seats ponchonorm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 01-15-2011 08:59 PM
different seats mp4life23 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 09-17-2010 11:24 PM
What to use on seats GTO_Addict Interior Discussions 4 05-02-2007 04:36 PM
