1964 gto - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-13-2012, 06:43 AM Thread Starter
1964 gto
Can someone help me find how to ID original motor
mikey9743 is offline
post #2 of 5 (permalink) Old 10-13-2012, 07:00 AM
You can find the casting and date codes on the distributor pad and the engine letter code is on the front of the block under the passenger side head. The head code is cast on the center exhaust ports just above the manifold.
05GTO is offline
post #3 of 5 (permalink) Old 10-13-2012, 04:29 PM
It's hard to prove the original engine on a 64 because that's before Pontiac started stamping the partial VIN on the blocks. Best you can to is to look up all the codes as 05GTO suggested and see if the date codes are "reasonable" for when your car was built and also are the correct casting and engine codes for what's supposed to be in the car. Having the PHS doc can help nail all that down.
ID:	15841   Click image for larger version
post #4 of 5 (permalink) Old 10-13-2012, 05:00 PM
Oldeboy's Avatar
Bear,
Could you remind me where the partial VIN on the motor would be?
Thank you.
Oldeboy is offline
post #5 of 5 (permalink) Old 10-13-2012, 08:20 PM
Originally Posted by Oldeboy View Post
Bear,
Thank you.
Stamped vertically next to the timing chain cover on the passengers side of blocks built after mid-year 1967.
05GTO is offline
my 1964 gto EDDIE COOK Member Introductions 16 12-12-2011 01:47 PM
1964 GTO-what to do with it? firemedicvin 1964-1974 Tempest, Lemans & GTO General Discussion 47 11-29-2011 12:55 PM
1964 Gto colonial83 Member Introductions 9 06-08-2008 08:32 AM
