1966 GTO Build Sheet - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-14-2012, 06:18 PM Thread Starter
Looking at buying a 1966 GTO from a classic car dealer which said is number matching car. what my concern is on the build sheet
It has Tempest/GTO on the top. I can tell motor has two barrel manifold with a adapter two to four . Did they use 2 barrel on 1966 GTO 389?
Pat
GTOpat is offline
post #2 of 4 (permalink) Old 10-14-2012, 06:51 PM
jmt455's Avatar
There was a 2 barrel option in 1967 and 68, but I am not sure it was available in the 1966 model year.
I would not buy one of these cars without first getting the vehicle documentation package from Pontiac Historic Services (PHS).
The document package will confirm all of the colors, dates, options, engine/trans/rear axle information for the car; all you need to provide in the VIN. It's well worth the $65 cost to make sure you are getting the "real deal".
PHS Historic Services
If you are in a big rush, you can get the initial report faxed to you within a couple of hours for an extra $15.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 4 (permalink) Old 10-14-2012, 08:00 PM
Quoted: 98 Post(s)
No 2bbl option on the '66. Get a PHS if you're thinking seriously about buying the car. Cheap insurance.
post #4 of 4 (permalink) Old 10-14-2012, 09:56 PM
The 2bbl GTO wasn't an optioned until 67,
Here are the GTO engine codes for 66;
Here are the 66 2bbl engines used on the b-body cars;
Name:	66 letter codes.jpg
ID:	15847   Click image for larger version
Name:	66 2bb carbs.jpg
05GTO is offline
build sheet decode help 68GTO4004Spd 1964-1974 Tempest, Lemans & GTO General Discussion 0 06-03-2011 06:03 PM
build sheet revup47 1964-1974 Tempest, Lemans & GTO General Discussion 1 05-04-2010 08:23 AM
I found myself a build sheet Priest 1964-1974 Tempest, Lemans & GTO General Discussion 6 03-22-2010 03:06 PM
build sheet 1bad69 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 07-14-2008 10:35 AM
1971 Build Sheet 1971GOAT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 02-06-2008 08:25 AM
