1966 lemans with 295 tires, any ideas ??? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-01-2013, 06:16 PM Thread Starter
Hello,
I'am beginner in measuring tires. I have a 1966 pontiac lemans with 15" rear rims but I don't remember the width, I think they are 8". I've just tried mastercraft tires 295/50/15". There's enough space from the back of tires but the problem is in the front side. They rub exactly in the bottom of fenders chrome. I have some photos for the tires. I can take more photos if you want. Any ideas to get these tires fitting well ?
The first picture with the previous tires, I think they were 225s
Best Regards from UAE.
uae2k is offline
post #2 of 7 (permalink) Old 03-01-2013, 09:32 PM
Looks like you need a wheel with 2-3 more inches of backspacing,
05GTO is offline
post #3 of 7 (permalink) Old 03-01-2013, 09:34 PM
Quoted: 23 Post(s)
-more offset on your rims if you have 2 more inches to the inside.
-cut or roll your inner fender lip
-pump up yoru air shocks 80's style
-put 255's on and lower it to where it should be
when you jack up the suspension it changes the whole geometry, what little traction you get from a 2 inch wider tire is negated by the harsh ride, terrible cornering and excessive wear on parts from the pounding they will take, just my $.02.
Instg8ter is offline
post #4 of 7 (permalink) Old 03-02-2013, 11:09 AM
Yep, you need wheels with more backspacing. Hit Google using search terms like "how to measure wheels", "wheel backspacing", etc. to find out how all the measurements work. Then get yourself one of these:
http://www.summitracing.com/parts/php-01201
That'll help you figure out exactly what you need.
If you're running disc brakes, don't forget to allow for caliper clearance.
post #5 of 7 (permalink) Old 03-02-2013, 01:40 PM Thread Starter
Thanks guys for your help
I will post new photos once I apply these solutions.
uae2k is offline
post #6 of 7 (permalink) Old 03-02-2013, 05:05 PM
67 Basket Case Restorer
Too Many Projects's Avatar
Yep, too much dish on the outside of the wheel. A 295 will fit with the right offset, but that would entail new wheels. A 255-60 may work with those wheels.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #7 of 7 (permalink) Old 03-02-2013, 05:32 PM
I have 295/50/15'S on the back and had to trim the inside of the inner fenderwell to get them to fit without rubbing. I trimmed right about to the mountinng screws for the chromed trim to get them to fit without rubbing.
1966 lemans 383 conversion chaviebuffalo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 06-05-2012 10:58 PM
1966 LeMans A/C Beef 66 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 11-19-2011 05:10 PM
1966 Lemans will not start Twokeela 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-24-2009 08:59 AM
