1966 tri power vacuum lines placement - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-23-2014, 09:22 PM Thread Starter
I just installed my 66 Tri power on my 67 GTO. I have a 400 motor with an automatic transmission and I don't have a clue (I forgot) as to where to put the Transmission and Distributor vacuum lines. Can I get a picture or a description? I have the brake booster and "F" line to the PCV connected.
Jax
xkeots is offline
post #2 of 2 (permalink) Old 11-24-2014, 11:24 AM
Quoted: 103 Post(s)
Easy enough. You need manifold vacuum for both the trans modulator and the vacuum advance. Originally, these units had hollow carburetor studs to draw vacuum from. They are available. Or, you could tee off the back of one of the carbs. Has to be manifold vacuum, though (like your PCV and Booster lines).
1966 gto tri-power rebuild yesteryear 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 12-26-2012 03:28 PM
1966 Tri-Power Idle Circuit yesteryear 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-26-2012 01:40 PM
overheating problems --1966 389 tri power khinton 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 09-07-2012 01:17 PM
Correct parts placement `65 tri-power Rukee 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 12-14-2007 11:23 AM
