1967 400engine question - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-15-2015, 09:09 PM Thread Starter
Gribbuckeye's Avatar
I came home today to decided to pull all the tune up parts. I decided to put new plugs and compression check I have the old plugs out for review. Here is the bad news The compression runs 140 to 150 psi on all cylinders, except for #1 cylinder. That one is 60 psi. I have re-ran the check a couple of times to see if it was my tool. I think the reading is accurate. The spark plug does not show any indications of oil fouling.
No external air noise. No exhaust gas in the radiator. No over heating. No water or oil leakage. #3 cylinder pressure is 140+ like the rest of the engine. This would lead me that the head gasket is holding. If the rings were bad, then there would be oil fouling on the plug. The plugs are fairly even with color. Usually plugs tell the health of the engine, but my plugs are more fuel wet as I don't drive it long enough to heat them up. So, the plugs looked like I expected them. The rings let some blow by but is even across all eight cylinders. The next guess would be lose rocker and I don't think so, as valve train noise seems normal.
My guess is the exhaust valve. This seems to fit the symptoms. The engine was not built to run on unleaded fuel and it has been running on unleaded since the 70's.
please any nadvice would be helpful
Gribbuckeye is offline
post #2 of 4 (permalink) Old 06-16-2015, 08:54 AM
Quoted: 4 Post(s)
Sounds like it could be that the intake valve is not opening properly, thus not filling the cylinder properly. This could be a loose or broke rocker, bad lifter, or cam lobe going flat.
When I broke an exhaust rocker, it would cough and pop back thru the carb, cause the exhaust had no place else to go. But with an intake not opening correctly, it would not have this symptom.
Hey, it's just an idea. I'm not a diagnostic expert.
oldskool is offline
post #3 of 4 (permalink) Old 06-16-2015, 09:05 AM Thread Starter
Thank you for the thoughts/idea, just one more piece of fun
post #4 of 4 (permalink) Old 06-16-2015, 06:41 PM
Quoted: 118 Post(s)
My guess is a burnt exhaust valve, too. My '67 GTO burnt an exhaust valve on #1 in 1988. You can do a leak down test to verify, or if you have true dual exhaust without a crossover, you can go back to the tailpipe and listen to it pop and miss out of that bank. A leakdown test will tell the story, though. Good luck, and tell us what you find!
1967 GTO - Headlight Question Beefcake77 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-11-2015 10:13 PM
1967 Rear Axle Question GTO4UNME 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 09-28-2014 08:49 PM
1967 Gto decoding question. bears369 1964-1974 Tempest, Lemans & GTO General Discussion 14 09-26-2014 10:48 PM
1967 kick panel question busaben 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 09-19-2013 08:09 AM
Seatbelt question - 1967 GTO Beefcake77 1964-1974 Tempest, Lemans & GTO General Discussion 11 09-10-2013 02:21 PM
