1967 Brake Question - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-08-2017, 10:20 AM Thread Starter
mj535's Avatar
1967 Brake Question
I have a 1967 LeMans with drums all around and a brake booster. Discs are a future project. Trying to make them work for now..
I find the application of braking power to be very abrupt. I press slowly and then they apply very strongly with a fraction of an inch in pedal movement. I can't seem to get used to it. Can I engineer this out? Is there an adjustment? Are drums supposed to be power?
Any insight would be appreciated.
Mark - Acton, MA
mj535 is offline
post #2 of 2 (permalink) Old 11-08-2017, 05:25 PM
GTOJUNIOR's Avatar
Quoted: 65 Post(s)
Yes they did have Power Drum brakes. Other then grabby quickly are there any other issues, Pulling to one side, Dragging, or such.
I would double check the adjustments and hardware as well as the shoes. Any contamination of the shoes with grease/oil can cause such conditions.
If all checks out then inspect the booster, Vacuum, Vac line and check valve.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
1967 Lemans 4 piston brake caliper question roycejb 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 03-12-2018 11:58 AM
brake question par4n1 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 10-05-2015 08:16 PM
1967 400engine question Gribbuckeye 1964-1974 Tempest, Lemans & GTO General Discussion 3 06-16-2015 06:41 PM
Brake Question Wilma 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 05-18-2015 02:54 PM
1967 fuel and brake line diagram needed busaben 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 06-06-2012 12:11 AM
