1967 Gto decoding question. - Pontiac GTO Forum
post #1 of 15 (permalink) Old 09-24-2014, 03:04 PM Thread Starter
Im decoding a Gto, using Potiac power website for help.
It shows the YS 9786133 engine block is for Gto California model.
Are they all California models or is this something different.
Sorry if this is a stupid question
Thanks,
Kevin
bears369 is offline
post #2 of 15 (permalink) Old 09-24-2014, 03:43 PM
Quoted: 99 Post(s)
YS is the standard 335 HP GTO engine for automatic trans cars, all states. The California model will have AIR, as well as a specific distributor and carburetor. My '67 YS is from Tennessee, and my buddy's is a California car. Same engine code and block on both cars, but his has the AIR pump and all the plumbing.
post #3 of 15 (permalink) Old 09-24-2014, 04:05 PM Thread Starter
Thanks Geetee,
I figured it was something with emissions. Mine is from Kansas.
Does this option, have any effect on the sale price of a car?
bears369 is offline
post #4 of 15 (permalink) Old 09-24-2014, 05:35 PM
Quoted: 99 Post(s)
If it's originally a CA car, yes. Complete cars are worth more. Since many of these cars were stripped of the air pump and equipment early on, replacing this equipment is difficult and expensive. An original Kansas car would not have come with anything other than the PCV valve. No AIR pump or other equipment.
post #5 of 15 (permalink) Old 09-25-2014, 06:01 PM
Kevin,
The letter code for a CA A.I.R block is WW for manual transmissions and XE for automatic transmissions.
67 was the first year to document the blocks, early 67 used the engine unit number stamped with the letter code on the front of the block and later in 67 they included the last part of the VIN on the block next to the timing chain cover. The engine unit number can be found on the PHS Documents (billing history).
05GTO is offline
post #6 of 15 (permalink) Old 09-25-2014, 06:21 PM
Quoted: 99 Post(s)
I don't show an XE code for Tempest/GTO engines in my engine chart (1967 Pontiac Service Manual). The YS shows no AIR, but interestingly enough, there is no 335 HP auto trans engine listed for AIR....only the 360 HP YR code. My buddy's all original, born with CA '67 has a YS coded block with the AIR intact. The '67 Pontiac manual shows WW for 335 hp AIR, and WV for 360 hp AIR, both manual trans.
post #7 of 15 (permalink) Old 09-25-2014, 06:29 PM
specific distributor and carburetor for CA AIR ?
GTO Guy can you elaborate on the following with the California model will have AIR, as well as a specific distributor and carburetor.
I have a Fremont, California Plant 1966 GTO that I would like to more fully understand all about it. The engine is all original and numbers matching.
I did not realize that it has a specific distributor and carburetor. The engine block has the WW stamped on it.
Thanks for your knowledge and expertise.
PONTIAC CLASS is offline
post #8 of 15 (permalink) Old 09-25-2014, 06:45 PM
Quoted: 99 Post(s)
PC, the distributor for your engine should be #1111103. I do not have the carb number handy. If I find it, I'll post it, though!! Pontiac fine-tuned every engine, with a specific advance curve and fuel metering calibration to match every camshaft, compression ratio, and application. Very sophisticated for the times.
post #9 of 15 (permalink) Old 09-25-2014, 06:51 PM
Here is a listing from Wallace for 335hp and 360hp;
ID:	46322   Click image for larger version
05GTO is offline
post #10 of 15 (permalink) Old 09-25-2014, 07:08 PM
The manual transmission Quadrajet A.I.R. part number for 1967 is 7037263 and was used for both the 335 & 360HP, the automatic A.I.R part number may have been 6037262.
05GTO is offline
Decoding 70' GTO Trim Tag gmjack 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 04-01-2014 05:38 PM
Seatbelt question - 1967 GTO Beefcake77 1964-1974 Tempest, Lemans & GTO General Discussion 11 09-10-2013 02:21 PM
Data plate decoding GTO-68 GTO viking 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 2 07-26-2011 05:58 PM
Help with decoding my 66 gto nmiller5000 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 01-31-2010 10:07 AM
1967 gto suspension question ozkar_67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-07-2008 01:04 PM
