1968 GTO Ram Air ii - Pontiac GTO Forum
post #1 of 13 (permalink) Old 10-15-2014, 02:54 AM Thread Starter
1968 GTO Ram Air ii
Hey everybody. New here to the forum because of a GTO I found while on vacation in the midwest. Its a 1968 GTO ram air ii. All matching numbers but the rear axle assembly (which is from a chevelle). There is definitely rust and everything needs rebuild. Any thoughts on this find and what the value might be? I appreciate any replies. Thanks!
bjackson83 is offline
post #2 of 13 (permalink) Old 10-15-2014, 08:49 AM
ppurfield001's Avatar
Searched around on-line and found one reference to Ram Air II -- "By mid-year 1968, a new option called the Ram Air II would debut, with newly designed high flow "round port" (on the exhaust side) cylinder heads."
Appears as if it is possible that this engine is rare.
ppurfield001 is offline
post #3 of 13 (permalink) Old 10-15-2014, 09:07 AM
Welcome.
Yep RA II is a rare bird.
Member on here is/was restoring a matching #s convertible recently. It would be nice to see some pictures if you want a value assessment.
post #4 of 13 (permalink) Old 10-15-2014, 09:17 AM
Quoted: 103 Post(s)
Missed out on one 20 years ago for $3500. Crystal Tuqoise/white vinyl top, white interior. Slot mags and jacked up. No rust, but needing a restoration. Passed because I was in the middle of buying a house. Ram air II is the first round port engine/car, and is very rare and valuable. And a very good performer, too. Ram air II cars are worth probably 3 times what a garden variety GTO is worth. Approaching or equalling Judge value.
post #5 of 13 (permalink) Old 10-15-2014, 10:22 AM
I believe 199 examples were built in both convertible and hardtop forms. There is a Black on gold ragtop that was found in a barn in upstate NY that was all original, was purchased for approximately 10k, the new owner ran the numbers, and it is a matching numbers 4 speed ram air two car. I have heard he was offered 500k, but remember, thi sis a survivor car featured in magazines.
To Me the 68 Ram Air 2 is the holy Grail of 68's. I have never seen one, and have only to date seen ram air two firebirds.
I would snap that up if you are financially able to.
Good luck and welcome!!!
Anthony
PS if it is Nightshade green it is worth twice the dough!
Nightshade 68 HO is offline
post #6 of 13 (permalink) Old 10-15-2014, 09:26 PM
Quoted: 368 Post(s)
The book says: Released in June 1968, Ram Air II, head casting (exhaust center port) 96 with an "R" on the front port and "A" on the end port. Block code WY, manual trans, total production -199. Block code XW, automatic trans, total production -47.
Additional checks -Q-jet carb #7028273 -manual trans, #7028270 -automatic trans.
post #7 of 13 (permalink) Old 10-16-2014, 01:21 AM Thread Starter
Thanks for the info everybody. I will get some photos up when I receive them. Still need to do some homework before I pull the trigger on this one...
post #8 of 13 (permalink) Old 10-16-2014, 07:44 AM
If it's a real RA II and numbers-matching (or even if it's "just" a real RA II). It's worth a ton. What's the asking price, if you don't mind?
post #9 of 13 (permalink) Old 10-16-2014, 02:13 PM Thread Starter
I can get it for 6k range. I will need to run the numbers first, and the rear axle assembly out of a chevelle worries me a bit. And seeing as how I live in CA and the car lives in the Midwest means I have to go through a third party to get the info I need doesn't help. Also need to make sure the whole car isn't rusted to the point of no return
post #10 of 13 (permalink) Old 10-17-2014, 08:30 AM
If that's a real RA II engine, the engine alone will probably bring 6k (or more).
How to tell if a 1968 GTO had factory Ram Air kj1556 1964-1974 Tempest, Lemans & GTO General Discussion 20 01-21-2016 05:31 PM
70 gto non ram air to ram air 1970gto455conv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 09-05-2014 05:12 PM
can you turn the ram air hood into a functional ram air? court_jester06 Intake and Exhaust Discussions 12 07-25-2010 01:36 PM
1968 Ram Air Carb Pan ..... ramairthree 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-04-2009 05:52 PM
1971 - 72 GTO Ram Air air filter slickman 1964-1974 Tempest, Lemans & GTO General Discussion 1 10-19-2006 08:44 PM
