1968 GTO Ram Air II? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-30-2014, 11:58 AM Thread Starter
Started a new thread on this one guys...here are the pics of the GTO I found out in the midwest. Owner says its a Ram Air II. I still need to run the vin with PHS. The guy I sent out to take pics couldnt find numbers on the engine or trans. Where are they located? Any thoughts or concerns on this goat? Any way to tell if that is the Ram Air II motor by looking at it? Thanks for your replies!
ID:	48554   Click image for larger version
ID:	48562   Click image for larger version
ID:	48570   Click image for larger version
ID:	48578   Click image for larger version
bjackson83 is offline
post #2 of 6 (permalink) Old 10-30-2014, 12:11 PM Thread Starter
Also any value estimates if it is what he claims it is?
post #3 of 6 (permalink) Old 10-30-2014, 04:14 PM
There is a thread under Technical Discussions titled "Decoding a 400 small block." Recommend you look at that thread. It will answer your question on location of numbers. Matt
Matthew is offline
post #4 of 6 (permalink) Old 10-30-2014, 05:53 PM
Quoted: 367 Post(s)
NOT a Ram Air II. Heads clearly show #16 on the center exhaust port. RAII heads are #96 and have an "R" cast on the front port and "A" cast on the rear port. #16 heads are the standard GTO heads.
post #5 of 6 (permalink) Old 10-31-2014, 01:43 PM
Quoted: 102 Post(s)
What Jim said. And even if it's the correct block, the correct heads will set you back about $5000.
post #6 of 6 (permalink) Old 11-03-2014, 02:39 PM Thread Starter
Thanks for the replies. Exactly the info I was looking for
How to tell if a 1968 GTO had factory Ram Air kj1556 1964-1974 Tempest, Lemans & GTO General Discussion 20 01-21-2016 05:31 PM
1968 GTO Ram Air ii bjackson83 1964-1974 Tempest, Lemans & GTO General Discussion 12 10-18-2014 09:15 AM
70 gto non ram air to ram air 1970gto455conv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 09-05-2014 05:12 PM
can you turn the ram air hood into a functional ram air? court_jester06 Intake and Exhaust Discussions 12 07-25-2010 01:36 PM
1968 Ram Air Carb Pan ..... ramairthree 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-04-2009 05:52 PM
