1968 Radiator Shroud- Save it? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-30-2015, 05:43 PM Thread Starter
Is this worth repairing? Worst side is the passenger side as shown.
ID:	63425   Click image for larger version
shoeman68 is offline
post #2 of 5 (permalink) Old 08-30-2015, 06:32 PM
Quoted: 390 Post(s)
Looks to me to be save-able. I suppose it is all about your budget. You could get a better used radiator support - which may be pricey, or a new repro which may be near close to the original fit but not quite and has to be modified. You might have wished you kept and repaired the original.
So my vote would be to keep the original because it is factory and you know it fits correctly. and I'd repair the rot and clean it up with a sand blasting. If you gotta add a few small sheet patches, so what, you can make them look pretty good to the average person.
post #3 of 5 (permalink) Old 08-31-2015, 08:20 AM
Easily fixable and no one will ever see the repairs if done right. Core supports are a very common rust spot right were yours rotted out. Very hard to find an undamaged unit and repops are not that good so I would say wholeheartedly, yes, fix it.
post #4 of 5 (permalink) Old 09-03-2015, 09:36 AM
Quoted: 117 Post(s)
Triple that.....repair and save. It'll fit right, be original, and save you money. One less Chinese part on your car, too. Win-win!
post #5 of 5 (permalink) Old 09-03-2015, 06:42 PM Thread Starter
Thanks for the answers. It will be saved!!!
Painting Radiator Shroud Falco21 Exterior Discussions 15 05-21-2011 08:30 AM
Radiator Fan Shroud Three Deuces 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 01-16-2010 02:16 PM
Radiator shroud Poncho Dan 2004-2006 GTO General Discussion 12 08-23-2009 11:25 AM
radiator fan shroud for 67' GoToIt 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-25-2007 11:42 PM
