1968 Safe-T Track Help Decoding - Pontiac GTO Forum
post #1 of 6 (permalink) Old 07-12-2009, 07:53 PM Thread Starter
Lukeduk1980's Avatar
Send a message via Yahoo to Lukeduk1980
OK, Here is the code off of that rear end some of you guys were unsure of.
KD 0 or a 6 3362
What does the KD and the rest of the numbers mean? ANyone please he,lp me with this one. Tnanks.
Lukeduk1980
Lukeduk1980 is offline
post #2 of 6 (permalink) Old 07-12-2009, 08:53 PM
Check the code, in 68 WD is for an open and YD is for a Posi, both are for a 2 Pinion 2.93 ratio rear end.
05GTO is offline
post #3 of 6 (permalink) Old 07-13-2009, 08:39 AM Thread Starter
Yeah, I checked the code, definately a KD. The rear axle has so much rust on it and the they did not stamp these rear axles very well but I can confirm that it is a KD code. Unfortunately, I doubt this is a posi since the when I turn one wheel, the other does not turn.
The code is KD 0 or a 6, etc. etc. It is also a 12 bolt reart end. any advice???
Lucas
post #4 of 6 (permalink) Old 07-13-2009, 09:53 AM
12 bolt rear ends were not used on GTO until 70 and then only with a 455, your rear end comes back as a 68 or 69 Chevelle with 2.73 ratio.
Rear Codes, 1968 Chevelle
69 Chevelle Rear End Codes
05GTO is offline
post #5 of 6 (permalink) Old 07-13-2009, 10:45 AM Thread Starter
Wow- So, my rearend came out opf a 1968-69 chevelle. Thats something new! Thank you very much my friend for the information!
Also, the code information was on the front passenger side of the axle. From the looks of your website, the codes for the chevelle are on the back. Am i seeing this right or no?
Also, can you or anyone else point me in the direction or website of what the rest of the numerical codes mean? Thanks
Lucas
post #6 of 6 (permalink) Old 07-16-2009, 07:41 PM
67 Basket Case Restorer
Too Many Projects's Avatar
The KD are for the 2.73 open(non-posi) axle. The next figure is probably an 0 to go with the 6. 06 is June. The 33 would be the day of the month but can't be, so you aren't seeing something clearly. Also the last 6 is probably a B to indicate which plant assembled it and the 2 indicates it was built on the second shift. Try using very fine sand paper and then a crayon to fill the stamps to read it better. Also, find the casting number in the lower corner of the center section. That will tell you what year it was for.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
Great Lakes/Midwest Track Days - 2009 Feffman Great Lakes 5 07-28-2009 06:35 AM
Pedders Suspension Benchmark Track Testing & New Jersey Track Day dms Drive train, suspension, alignment and brakes. 7 04-09-2009 02:50 AM
2008 Track Days (Road Course) Invitation Feffman Racing and Kill Forum 4 04-11-2008 06:23 AM
Southeast Goats--Carolina Goat Herd Track day lisatw151 Southeast 8 10-19-2007 11:47 AM
