1969 GTO brackets - Pontiac GTO Forum
post #1 of 8 (permalink) Old 04-03-2012, 09:32 PM Thread Starter
joesweeting's Avatar
1969 GTO brackets
I have a 1971 455 with 1971 400 “96” heads. The previous engine in the car was a 1973 400 engine. To use the alternator and power steering pump, which I’m assuming are from a 1973 including water pump. Do I need 71 or 73 mounting brackets? I have 69 brackets on hand.
Thanks,
Joe
joesweeting is offline
post #2 of 8 (permalink) Old 04-04-2012, 01:45 PM
Assuming the heads have all the bolt holes on their fronts for mounting accessory brackets...
You should be able to use whatever you like: 71, 73, or 69. What matters is not trying to mix and match components from different years. For example, if you use 69, then use 69 "everything" --- brackets, all the pulleys, acessories, etc.
post #3 of 8 (permalink) Old 04-04-2012, 05:01 PM
Keep in mind the brackets may have changed mid year 69, so the mid year 69 thru 73 and maybe newer should use the same brackets.
In early 69 pontiac used a 4" water pump and changed to 4.5" mid year.
05GTO is offline
post #4 of 8 (permalink) Old 04-04-2012, 05:12 PM
Yep they sure did, but the brackets didn't change when they did that. What did change was they went to a "deeper " water pump pulley to maintain all the alignments.
post #5 of 8 (permalink) Old 04-04-2012, 05:34 PM
Do you have a part number for that deeper water pump pulley?
05GTO is offline
post #6 of 8 (permalink) Old 04-04-2012, 09:55 PM
Yep, that would be 9799127 without a/c, 9799130 with a/c.
Why do I know? because I went though -all- of this with my 69. It was originally an early production short pump snout car, I replaced it with a long snout aftermarket high flow pump, and as if that wasn't enough grief - I also went to an SFI-rated balancer that wouldn't allow the original a/c compressor drive crank pulley to fit. Oh... I had -lots- of fun
post #7 of 8 (permalink) Old 04-05-2012, 09:06 PM
Thanks, I have an early 69 (9790071) block in my 67, After going thru several sets of pulleys I finally found the 4" WP from Ames.
05GTO is offline
post #8 of 8 (permalink) Old 04-24-2012, 02:07 AM
your 73 brackets should all work on the 71.
pontiac is offline
Alt Brackets 67158 1964-1974 Tempest, Lemans & GTO General Discussion 3 09-12-2011 08:00 PM
Motor brackets GTOKID64 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 08-31-2011 06:40 PM
73' 455 alt/PS brackets? Instg8ter 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 12-23-2010 09:26 AM
Engine Brackets dakuhns 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 03-02-2010 06:31 PM
