1969 GTO deck lid emblem? - Pontiac GTO Forum
post #1 of 18 (permalink) Old 08-08-2014, 08:33 AM Thread Starter
Grant1969's Avatar
Does anyone sell a stick on type GTO deck lid emblem for a 1969?
Grant1969 is offline
post #2 of 18 (permalink) Old 08-08-2014, 09:07 AM
Why would you want that? No one I know of sells a "stick on" emblem and factory had the pins and nuts. That is correct and easily installed. If you are afraid to drill holes in the paint you should put masking tape down before you drill and then touch up with a little paint around the holes to prevent rust. I hope this helps.
post #3 of 18 (permalink) Old 08-08-2014, 09:17 AM
Roger that's Avatar
If you want a stick on GTO badge, the "new" 2004 -2006 GTOs probably used them. Won't be the correct size or font though.
Roger that is offline
post #4 of 18 (permalink) Old 08-08-2014, 09:34 AM Thread Starter
Grant1969's Avatar
The exact reason is because I don't want to drill holes. The car has already been painted and I have seen professionals screw up this easy installation. To complicate matters, I don't know if during the repaint if the deck lid was replaced or the holes were filled so I don't know what I would be drilling into.
post #5 of 18 (permalink) Old 08-08-2014, 09:37 AM Thread Starter
Grant1969's Avatar
If it doesn't look original, I would prefer nothing.
post #6 of 18 (permalink) Old 08-08-2014, 01:22 PM
Try looking on the inside of the trunk where the badge goes, you might be able to see where the holes were.
post #7 of 18 (permalink) Old 08-08-2014, 01:26 PM Thread Starter
Grant1969's Avatar
No evidence of holes on the back side either.
post #8 of 18 (permalink) Old 08-08-2014, 01:44 PM
Could be a Lemans decklid. Look in the center portion and see if you can spot where the hole were filled in where the letters PONTIAC should have been. Again, drilling holes with the method I mentioned will work fine. Start with a 1/8" drill bit at the proper spacing between the pins using a template. If you need exact dimensions someone on here will be able to help. I'm off to work now or I'd give you them myself. Good luck!
Oh, and it's not a GTO without the emblems .
post #9 of 18 (permalink) Old 08-08-2014, 02:44 PM Thread Starter
Grant1969's Avatar
No evidence of holes in the center either.
Emblems don't make it a GTO my friend. The VIN and the numbers matching drive train make this a real GTO.
post #10 of 18 (permalink) Old 08-09-2014, 01:03 AM
Just trying to help.
66 GTO Deck Lid Alignment djmeston04 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 06-01-2010 09:00 PM
