1969 GTO tail light bulb sockets - Pontiac GTO Forum
post #1 of 15 (permalink) Old 07-21-2014, 08:37 PM Thread Starter
Mainlin's Avatar
I'm new to the forum as I just bought by first GTO. It is having issues with the tail lights and I've identified that a couple sockets aren't working right. One is an aftermarket replacement socket that doesn't appear to have any way to snap into the tail light housing like the originals. The other socket has an issue with the contacts in the socket not contacting the contacts on the base of the bulb. I can push the bulb in and it lights up.
I'd like to replace one or both of the sockets but I can't seem to find anyone that sells a correct replacement socket. The ones I find that are supposed to fit a 69-74 GM cars, will fit in the tail light housing but they don't snap in. The previous owner duct taped the replacement socket to keep it in.
Am I missing something? Does anyone know where to buy a replacement?
Thanks for any help!
Mainlin is offline
post #2 of 15 (permalink) Old 07-21-2014, 09:55 PM
pjw1967's Avatar
Ames page 169.
pjw1967 is offline
post #3 of 15 (permalink) Old 07-22-2014, 12:00 AM Thread Starter
Mainlin's Avatar
That's the same socket I'm finding everywhere else. It doesn't snap in. There is nothing to hold the socket in the housing. Am I missing something with this? My original sockets have latches on both sides that I have to push to release. There isn't anything like that on those in the Ames catalog or the ones that I'm finding at any other parts place.
Mainlin is offline
post #4 of 15 (permalink) Old 07-22-2014, 08:06 AM
SANDU002's Avatar
A few years back, I read an article on this problem and you can buy a replacement from NAPA that fits a chevelle that will work. You could also wedge a piece of metal between the socket and housing to hold it in place and use as a ground.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #5 of 15 (permalink) Old 07-22-2014, 09:23 AM
NAPA part # ECH LS6217
post #6 of 15 (permalink) Old 07-22-2014, 09:39 AM Thread Starter
Mainlin's Avatar
Thanks guys. That NAPA part looks just like all the other sockets. I'm going to have to figure out how to make it work.
I'm thinking I might be able to make some kind of clip or keeper with my 3D printer... If it works well then I'll post my results.
Mainlin is offline
post #7 of 15 (permalink) Old 07-22-2014, 10:05 AM
pjw1967's Avatar
I think what is in the Ames photo is correct. I just took these pictures of my '67.
This one shows the hole in the housing. You can see where there is a notch for the guide nub on the socket.
This is from the Ames catalogue. I circled the guide nub. It is right next to one of the copper clips for the ground. There is a copper ground on the opposite side.
This picture shows the guide nub on my socket next to the ground.
This last picture shows the black plastic tines that actually snap into the hole. There are 4 on one side and 3 on the other, with one of those being wider that the others. In my humble opinion the Ames socket is identical, remembering that my car is a '67. Hope this helps.
pjw1967 is offline
post #8 of 15 (permalink) Old 07-22-2014, 12:18 PM Thread Starter
Mainlin's Avatar
Thanks for the photos. Yes, the hole in the housing looks just like that and yes, the guide notch lines up. The problem I have is that the plug from the Ames catalog, and the others like it, is that they aren't staying in the housing. Maybe the one I bought is too cheap and not constructed well so the tines don't hold enough tension. In any case, the original sockets snap in and you have to squeeze them to release them from the housing. They don't look the one in your pictures. I'll have to see if I can get some pictures of mine tonight.
Mainlin is offline
post #9 of 15 (permalink) Old 07-22-2014, 12:24 PM
pjw1967's Avatar
Mine are original to the car as far as I know. And yes they are weak when it comes to staying in the housing. They will occasionally fall out, probably after hitting a bump. Old age and wear and tear. Good luck, and let us know if you find a better solution.
pjw1967 is offline
post #10 of 15 (permalink) Old 07-23-2014, 09:15 AM Thread Starter
Mainlin's Avatar
Here is a picture of the original light socket. The arrow is pointing to the depressable latch that holds the socket in the housing. I was hoping to find a replacement that also has this but it seems I'm out of luck.
I was able to get the lights all working last night and I think they'll be pretty reliable. The problem is that one of the sockets has been replaced and it's the kind of socket that doesn't latch so it pops out. I'm going to work on making a clip/bracket to hold it in. My goal is to make something that doesn't require any modification to the existing housing and just snaps in...
Mainlin is offline
1969 tail light bezels 69GTOCONVLOVER 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 01-22-2014 12:05 PM
1969 GTO Rear Tail Light Harness SW63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-08-2012 01:10 AM
Tail Light Bulb Question Baaaa04GTO Exterior Discussions 7 04-27-2011 08:27 AM
67 Radio light bulb, heater controls light bulb? nedorama 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 09-26-2010 06:44 PM
Tail Light Assy Lamp Bulb Types? Groucho Service, Maintenance and Technical Discussion 17 09-15-2009 03:18 PM
