1969 Ram Air IV Intake - Pontiac GTO Forum
post #1 of 15 (permalink) Old 11-15-2014, 07:54 AM Thread Starter
I have a 1969 GTO that originally came with a ram air iv engine, I don't have the engine, instead i have a 1970 455 HO without the HO heads, it has standard heads. I want to install all of the ram air stuff without changing the heads and exhaust, intake manifolds. Can I use the stock intake manifold with the ram air stuff (heat ducts, air cleaners etc).
waterfire69 is offline
post #2 of 15 (permalink) Old 11-17-2014, 01:57 PM
ppurfield001's Avatar
Too bad you didn't get the original Ram Air IV with the car. Those engines are as rare as hound's teeth...Good luck with the work you want to do...
ppurfield001 is offline
post #3 of 15 (permalink) Old 11-17-2014, 02:04 PM
HP11's Avatar
Quoted: 24 Post(s)
Hounds' teeth are pretty common.....you must mean hen's teeth.
HP11 is offline
post #4 of 15 (permalink) Old 11-17-2014, 04:42 PM
Quoted: 103 Post(s)
Yes, you can use your intake. Not a problem.
post #5 of 15 (permalink) Old 11-19-2014, 04:28 PM Thread Starter
So I don't need the cross over to attach the ducts?
post #6 of 15 (permalink) Old 11-19-2014, 06:32 PM
You do need the crossover, unless you instead use block-off plates on those passages on each head.
post #7 of 15 (permalink) Old 11-21-2014, 04:17 PM Thread Starter
Sorry to keep bothering you Bear. Can the cross over be installed with a stock intake? From pictures it seems the ram air iv has a gap on each side for the cross over and the stock intake does not.
post #8 of 15 (permalink) Old 11-21-2014, 05:38 PM
Quoted: 368 Post(s)
No. The RA IV is 2 pieces, the intake and the crossover. The cast iron factory manifold is one piece to include the crossover.
I believe you can very carefully cut the exhaust crossover off of the cast manifold and clean it up (which I have read is done to save weight), then you might be able to use the RA IV exhaust crossover. This would make it look like a RA IV intake, but not 100% on being able to use the RA IV exhaust crossover.
It would be a lot of work.
post #9 of 15 (permalink) Old 11-22-2014, 06:58 AM Thread Starter
It sounds like it would be much easier to buy a ram iv intake. I assume that won't be an issue on the 1970 455 stock heads?
post #10 of 15 (permalink) Old 11-22-2014, 07:11 PM
Quoted: 368 Post(s)
Intake will work, but the RA IV has a taller intake port 2.18" vs 2.05" and is just a hair wider, there will be a mis-match at the top between the intake and head. If rebuilding the engine, you can port match the heads using the RA IV intake gasket. If you did not gasket match the heads, I might build up the intake port on the RA IV with epoxy and shape it to match the gasket used for your stock heads. Moroso A&B Epoxy - Free Shipping on All Orders @ JEGS
Wanted 1969 Ram Air IV Engine waterfire69 2004-2006 GTO General Discussion 2 11-14-2014 07:45 PM
1969 RAM AIR III heads mrvandermey 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 44 03-18-2014 05:32 AM
1969 GTO ram air iv car need engine waterfire69 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 09-17-2012 04:46 PM
1969 Ram Air Hood Pan Install ? plastic61 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 03-20-2011 08:20 PM
Ram air intake warsgoat Service, Maintenance and Technical Discussion 1 10-14-2005 01:33 PM
