1970 GTO fuel gauge level not right - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-02-2016, 03:40 PM Thread Starter
I bench tested the sending unit with the gauge and it goes from empty to full correctly according the gauge reading. (moved the float manually out of the tank)
Problem is I put around 4 Gallons of gas in it still shows empty. It has not moved from 0-4 gallons.
The pickup length seems to be correct as when I pulled the tank out it had about 1 gallon of gas in it and the car still was running before I removed the tank.
My guess is the float arm is not bent-angled properly or wrong length to start moving with that little amount of gas in there.
I bought the correct sending unit from one of the GTO online sources so it should be the correct one for the car.
The tank looks correct but not not 100% sure. is there numbers on it to verify it?
Just wanted verification before I try to start bending the float rod what else could it be or should be checked first.
michaelrj9 is offline
post #2 of 3 (permalink) Old 02-02-2016, 06:44 PM
pjw1967's Avatar
Read this. Testing procedure for reading empty all the time.
https://www.fillingstation.com/artic...ugetesting.htm
pjw1967 is offline
post #3 of 3 (permalink) Old 02-03-2016, 09:19 AM Thread Starter
It all checks out good. I get 0 to 96 ohms or so and it moves the gauge outside the tank and the float "Floats"
What I believe the problem to be is the float is hitting the baffle. When I set the unit in the hole almost all the way down, all it will move is a 1/2" until it hits the baffles. When the float goes up it will even need more room then the 1/2" I have right now.
Anyone have a picture down the sending unit opening in the tank so I can compare what it looks like to mine? Or better yet a picture of the tank cut apart
Anyone ever hear of this happening?
68 GTO Fuel Gauge Sending Unit mwatson1647 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 10-13-2014 08:34 AM
71' GTO fuel gauge reads 1/4 tank when full Animalmutha 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 05-20-2014 06:31 PM
Fuel sending unit/fuel gauge issue xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-08-2012 08:12 PM
fuel level sender ohm readings? virginiavenom 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 01-04-2012 03:34 AM
fuel pressure gauge & boost gauge sdgoat Service, Maintenance and Technical Discussion 4 05-12-2006 09:34 AM
