1971 gto gr60-15 - Pontiac GTO Forum
 1Likes
  • 1 Post By Pinion head
post #1 of 2 (permalink) Old 11-25-2017, 06:27 PM Thread Starter
1971 gto gr60-15
What size tires do I need for my 71 GTO. They are 15x7 rims. Seems like I can use 225/60-15 or 235/60-15?
Thanks.
johng1971gto is offline
post #2 of 2 (permalink) Old 11-26-2017, 11:15 AM
225/60's are too small, the oem G60x15 Polyglas GT's are equivalent in height to a 245/60R15. not sure what's out there todayin a 245/60-15.
Having purchased & installed a ton of 255/60R15's, they fit propperly (the tread doesn't rollover) on an 8" wide wheel, have never liked using 255's on a 7" rallyII.
If your '71 GTO has factory firm ride Y96 suspension, it will set aprox an 1" higher than a standard '71 GTO, & if the springs are in good shape & have the body setting up, you most likely are going to want to fill up the wheelwell versus leave a big gap. Front & rear rocker height to ground as well as spring condition, are something to investigate.
johng1971gto likes this.
1971 GTO Resto brock20 1964-1974 Tempest, Lemans & GTO General Discussion 11 11-12-2014 02:34 PM
Help with 1971 GTO... Brad1971 1964-1974 Tempest, Lemans & GTO General Discussion 0 10-27-2014 07:59 PM
1971 GTO Convertible navychief 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-20-2011 07:38 PM
1971 GTO problems Boinks 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-24-2009 02:02 PM
1971 GTO... needs more umph! PontiacJack 1964-1974 Tempest, Lemans & GTO General Discussion 24 05-22-2005 07:02 PM
