1972 q-jet carb 7042272 - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-17-2011, 10:27 AM Thread Starter
Hey just askin if i can remove my afb carb and mount a 1972 q-jet #7042272 with no mods on my 66 389.
RUNVS is offline
post #2 of 4 (permalink) Old 02-17-2011, 01:56 PM
Thumpin455's Avatar
The AFB and Qjet have different mounting patterns. The AFB ks square bore like a Holley carb, both primary and secondary are the same size. The Qjet is spread bore with small primaries and huge secondaries. It wont bolt to your manifold, but you can swap a 67-72 intake on it or an aftermarket intake that will accept a Qjet. You can also use later 73-79 intakes, but they have EGR which isnt a problem, just a bit more complex and require a valley pan with a larger depression in them.
Thumpin455 is offline
post #3 of 4 (permalink) Old 02-17-2011, 11:45 PM Thread Starter
thanks, i will look for a aftermarket intake. or just rebuild that afb.
RUNVS is offline
post #4 of 4 (permalink) Old 02-18-2011, 10:21 AM
On "most" street motors, the factory cast iron intake will run with, or better than, aftermarket intakes - FWIW.
Jet Ski trip fergyflyer The Lounge 7 03-01-2010 11:35 AM
need help i.d.ing a Q-jet i got laying around danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 09-26-2009 11:49 PM
Quadra-Jet Conundrum BobG 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 07-10-2008 09:28 AM
Jumbo jet explosion PEARL JAM Audio & Video Clips 0 08-22-2007 10:56 AM
Jet Blast TexasRealtor The Lounge 1 11-08-2006 11:37 PM
