326 block and 400 block - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-17-2009, 06:10 PM Thread Starter
jbranontn's Avatar
Is the block the same for 326 as the 400 V8? I read on Pontiac Enthusiast site that "The Pontiac 350 is neither a big block nor a small block, it is a Pontiac V8. Other manufacturers had both small and big block motors, most notably Chevy, but Olds and Buick both had small or at least smaller block versions of their motors. Pontiac used one basic size block for everything, with the exception of the later 265 and 301 low deck motors that everyone wants to forget. "
Will parts from 326 engine interchange on 400?
1966 Pontiac Tempest Custom
jbranontn is offline
post #2 of 3 (permalink) Old 07-17-2009, 09:12 PM
67 Basket Case Restorer
Too Many Projects's Avatar
The pistons and crank won't but everything else will.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #3 of 3 (permalink) Old 07-18-2009, 10:55 AM
Quoted: 98 Post(s)
Olds motors are like Pontiacs....a 260 is the same size as the 455. Buicks likewise: a 350 and 455 are indistinguishable. Chevy, Ford, and Mopar had the "small-block-big-block" thing going....Pontiacs are all big-ish blocks, weighing what they do. They're certainly closer to a big block than a small block. Pontiacs DID differentiate between Small Journal And Big Journal motors....the 326-389-400 v8's had 3 inch main journals on the crank, whereas the 421-428-455 had 3.25 inch mains. As mentioned above, the parts will interchange. The most common performance block used is still the 400. It's more readily available than a 389, is of good size and power, and is affordable to build up. My favorite Pontiac engine is the 421. I've never owned one!
1967 400 engine ID confusion norcal65goat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 06-28-2009 05:32 PM
389 vs 400 Marauder 1964-1974 Tempest, Lemans & GTO General Discussion 2 12-11-2004 12:55 AM
