389/455 swap - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-26-2008, 12:28 PM Thread Starter
389/455 swap
will a 455 go in a 66 GTO w/o modifying mounts?
b
gtocrazed is offline
post #2 of 3 (permalink) Old 05-26-2008, 03:58 PM
Yes, It should not be a problem. Years a go I put a 455 in a 66 GTO, as I recall it was no issue. You may need to buy diffrent engine mounts. I can't remember. But no other mods were necessary....Eric
Eric Animal is offline
post #3 of 3 (permalink) Old 05-27-2008, 09:13 PM
Quoted: 118 Post(s)
It will bolt right in. It is the exact same size externally as the 389. Nobody will know it's not a 389 unless you tell 'em! The mounts are the same. Good luck........
Jeff
LS3 swap? GOAT06 Engine Discussions 14 03-07-2008 01:25 PM
1967 Trans Swap possible project Valsmere 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 10-16-2007 06:50 PM
05 Gto 5.7 Swap dvdslw Service, Maintenance and Technical Discussion 1 08-17-2007 03:50 PM
Swap Pontiac G8 6 auto speed into GTO dotocomo Service, Maintenance and Technical Discussion 7 07-02-2007 07:47 PM
