389 Rattles - Pontiac GTO Forum
post #1 of 24 (permalink) Old 09-19-2011, 09:34 AM Thread Starter
389 Rattles
Recently had 1964 GTO 389 professionaly rebuilt. Have appx. 1500 miles on it and have changed oil 3 times using Lucas zinc additive. After sitting and cold in the morning, it rattles like rod noise until pressure is up (2-3 seconds). It is getting progressively worse and I was told there is an oil check valve/spring where the oil filter mount bolts to the block that may be bad. I wonder if it is just a loose motor? Carries 50-60 psi once running. Any ideas?
roush05 is offline
post #2 of 24 (permalink) Old 09-19-2011, 12:20 PM
Sounds like lifters to me....maybe as a result of low oil pressure at start up. Eric
Eric Animal is offline
post #3 of 24 (permalink) Old 09-19-2011, 04:27 PM
Definitely a prime suspect. Do you have a way to record a video of it with sound?
BearGFR is online now
post #4 of 24 (permalink) Old 09-19-2011, 06:05 PM
Quoted: 99 Post(s)
x3. A video will help the rest of us in trying to determine if it's lifters or loose clearances.
post #5 of 24 (permalink) Old 09-20-2011, 08:12 AM Thread Starter
389 rattles
Not sure video would detect rod noise on initial cold start. Have been told that advanced timing (about 36 deg) and 91-93 octane produces "Ping" and along with decked heads and block may be running 11 to 1 compression. Had a mechanic tell me the motor will self destruct with cold starts and dry bearings as a result of loose clearance / worn bearings after 1500 miles??
Suggests: dished pistons to reduce compression, new bearings,rings, and polish crank. Hopefully has not been hurt. Is already .010 under.
roush05 is offline
post #6 of 24 (permalink) Old 09-20-2011, 08:20 AM
If that is in fact what's going on, it could have been caused by not priming the oil pump durring assembly. Now that the pump is working, replacing the rod bearings might be all that's needed. I would be sure to use some plasticgauge on them to check clearances when installing the new bearings.
post #7 of 24 (permalink) Old 09-20-2011, 08:59 AM Thread Starter
389 rattles
Thanks for responses. Maybe at this point new bearings will work if crank is not hurt. Is the advanced timing, higher compression, and pinging a factor in the bearing failure?
roush05 is offline
post #8 of 24 (permalink) Old 09-20-2011, 09:03 AM
I've been running 11.1 compression with the factory distributer and Tri-Power for 16+ years and have not had any bearing failures. I have seen cast pistions fail with pinging though. Be sure your running forged pistions.
post #9 of 24 (permalink) Old 09-20-2011, 09:07 AM Thread Starter
Do you run pump gas / octane boost? Maybe I can save this motor without major rebuild by just replacing rod bearings. Just want a dependable car.
roush05 is offline
post #10 of 24 (permalink) Old 09-20-2011, 09:11 AM
Yes I run on pump non ethanol premium gas, with the timing reduced. I do like to run race fuel about every other tank though, and man does it make a difference!!
Shift knob rattles CrazyGerman Drive train, suspension, alignment and brakes. 19 06-30-2009 02:26 PM
Interior Rattles Questor Interior Discussions 8 07-02-2007 10:55 AM
