389 RPM's - Pontiac GTO Forum
post #1 of 23 (permalink) Old 04-13-2013, 05:23 PM Thread Starter
Piedog's Avatar
389 RPM's
Driven my 64 twice now and not sure of how hard to push it. It's a 389 3 x 2 that was professionally built less than 1000 miles ago under previous owner to the tune of $10k. Nothing wild just solid. What kind of rpm's is reasonable for a solid 389?
Piedog is offline
post #2 of 23 (permalink) Old 04-13-2013, 05:48 PM
Quoted: 100 Post(s)
5200 max for a stock engine with factory rods. Without knowing what's inside, I wouldn't push it. Also, know that these engines will wind up like a small block Chevy, but won't hold together doing it. Keep an eye on the tack and keep the revs at 5k or under. I've had these engines up to over 6500 rpm, but it is very ill advised.
post #3 of 23 (permalink) Old 04-13-2013, 06:05 PM Thread Starter
Piedog's Avatar
Got it. The build was all top stuff crank, rods, pistons, cam, lifters, headers, etc but I'm not wanting to find out the hard way. Previous owner had tach redlined at 5,500. It gets there pretty quickly & my only current frame of reference is my LS2 which winds up a bit more, so this is a new experience...a very good one I might add. Thanks
Piedog is offline
post #4 of 23 (permalink) Old 04-13-2013, 06:41 PM
If you know for certain that it has good aftermarket forged rods in it, then you don't have to be quite so cautious. Factory rods were always the weak link. Keep in mind though that Pontiacs are torque motors and they make it all on the bottom end. Depending on which cam you're running, it's probably going to be all done a good bit before 6000 anyway.
post #5 of 23 (permalink) Old 04-13-2013, 07:47 PM
I agree with Bear. The truth is without more specifics, we really can't accurately answer this question.
'67 GTO 400 H.O. - 4 speed - 3.55 posi
67GTO4SPD is offline
post #6 of 23 (permalink) Old 04-13-2013, 09:13 PM Thread Starter
Piedog's Avatar
Thanks guys I got the answer I was looking for.
The invoice shows Impastato Racing Engines Chesterfield Twp MI did the build. There's a 3 page list of work and parts. Honestly I don't know what "squared and parallel decks" even is. I know what honing is but I'm not sure about "bore hone to 4085 with plates"? I can figure out "pin fit to pistons, cut & mag crank, balance blue print & dyno"! It goes on; Diamond pistons, Eagle rods, Competition cam & lifters, Trend moly pushrods, performance oil pump, etc etc.,
Bottom line is it the 389 is not a hi rev engine and I'll treat it accordingly....if it ever quits raining! Appreciate the help!
Piedog is offline
post #7 of 23 (permalink) Old 04-13-2013, 09:54 PM
Quoted: 23 Post(s)
You got ALL the goodies, but no need to push them to the limits...5500's a good number. Hope to see you and your car at the Dreamcruise...
Instg8ter is offline
post #8 of 23 (permalink) Old 04-13-2013, 10:04 PM
The specs you have listed above pretty much means everything was done right. "Squared and parellel decks" means the decks were cut and they were cut at the correct angle in respect to each other (90 degrees for a Pontiac). "Bore hone to 4085 with plates" means the engine was bored .030" over using a deck plates, which a plate that bolts to the head using the head bolts simulating the head being bolted on the engine. This is a better way to bore an engine because the normal distortion that is caused by the head being torqued is being duplicated by the plate. Most regular engine machine shops bore it with nothing bolted to the engine, and when the head is bolted on after it is bored, the bores aren't truly round (although the distortion is slight).
NOW - you've got me curious - Does it have the cam specs, and dyno numbers? What heads are on it? This has nothing to do with your question, I'm just curious what they did and what they used now!
It sounds like a very nice build!
post #9 of 23 (permalink) Old 04-13-2013, 10:17 PM
Sounds like a solid build! Nice find OP.
post #10 of 23 (permalink) Old 04-14-2013, 07:45 AM Thread Starter
Piedog's Avatar
All I have on the cam is the part number Competition Cams xe262(either H or 11) - 10. It has the original 9770716 heads. The block is from a 64 Catalina. I have the original 76x but it is shot. (The previous owner spent a ton having it built by a less than pro outfit only to find afterwards it was full of cracks. So long story longer this time he had a real pro do it.) I don't see any dyno numbers but I'm going to see if I can get them. The list of stuff is hand written on carbon paper & some is hard to make out.
I could try to copy, scan, & send pm if you are really interested.
Piedog is offline
High RPM Misfire kilkm68 Engine Tuning 4 04-10-2013 07:26 AM
Newbie wants to know RPM Dhongu 2004-2006 GTO General Discussion 6 10-31-2005 08:41 PM
Engine RPM mrbst47 Service, Maintenance and Technical Discussion 10 09-04-2005 02:05 AM
A/C Compressor off at what RPM ? westell Service, Maintenance and Technical Discussion 2 10-19-2004 02:14 PM
6.3 L V8, 500 hp at 5200 rpm and 500 lb-ft of torque at 5000 rpm Scissors Service, Maintenance and Technical Discussion 3 08-19-2004 01:27 PM
